Question about Kitchen Appliances - Others
Slush machine not freezing
If the mix is cold but not freezing, you may be low on refrigerant or the timer is in defrost (if it has that feature). if it's warm, either the solenoids are not opening or there is no refrigerant. check the exhaust. if there is little air flow, clean the condenser coils (air intake). if it's cold, the compressor is not functioning or no refrigerant. for low or no refrigerant, you have a leak. take it in for repair
Posted on Sep 08, 2014
SOURCE: I have an Ultra 2 bunn slush machine. One hopper
make sure it's mixed properly. if there is toomuch water, it'll freeze solid. if the mix is too rich, ice will form on the outside of the bowls. you may also have a low refrigerant level.
Posted on Feb 13, 2011
