Question about Jet 3 Ultra Power Chair
My jet 3 ultra seems to pull one way when going in forward like it pulls one way more than the other.
Pushing joystick forward and it wants to pull more one way that the other.
Posted by Ray Payne on
JoeT
    New Friend:
    Problem Solver:
  • 6 Answers
I suspect that your seat is out of alignment.
On the control side of you unit there is a lever which allows you to alter the position of the seat so if you lift this up and forward you should be able to 'square your seat' in a for and aft position.
Be sure to return the lever or else it will be quite unstable.
Joe
Posted on Aug 17, 2014
5 Related Answers
Anonymous
  • 29 Answers
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. [email protected]
Posted on Sep 07, 2009
Barry Nixon
  • 103 Answers
SOURCE: we have a problem with the joystick controller on
The joystick is a sealed unit. If there is a problem with the joystick then you have to replace the whole unit.
Posted on Dec 15, 2009
lennieg2000
  • 692 Answers
SOURCE: I just purchased a used
bobby
The batteries are not charged. The red light indicates low batteries and the clicking sound you hear is the electric brakes being energized. Now the problem could be bad batteries or a bad charger. If you have access to an off-board charger (maybe a friend or acquaintance might have one) plug it into the charger port located under the front of the joystick. Don't plug in the on-board charger at the same time. Charge the chair overnight with the off-board charger and you should see a red light(power) and a green light(if the chairgot fully charged) if the light is still yellow then the batteries are bad and need to be replaced. Your chair uses 2 U1 batteries and if there is a battery store near you get them there. Interstate makes a good battery if you have a dealer near you. Hope this helps Good Luck
Posted on Oct 23, 2010
Colin Taylor
  • 347 Answers
SOURCE: Hi i have a Jet
Good day,visit the manufacturer website & go from there.Alternatively,ebay is a trusted site to purchase parts also.Have a nice day,Colin.
Posted on Jul 26, 2011
Warren Woeste
  • 4 Answers
SOURCE: i have a jet 3 ultra motorized wheelchair and the rightside tire wont move forward or backwards,also the motor is very hot.what could be causing this?
The above solution is very good idea one other thing that is easy to over look is make sure the trans engage lever is in drive and if the trans is locked up you can find motor and trans. combo on that site [email protected] I hope this helped.
Posted on Oct 29, 2011
Why wont my jet 1 powerchair move with fully charged batterys
If the charger is unplugged and the freewheel levers are in drive position. The joystick should not have any flash lights on it, this indicates a flash code that needs to be addressed. If the lights are rippling up and down it could be locked out. some joysticks can be reset by pushing the horn button twice after turning it on within 10 sec.some are reset by pushing joystick forward until it beeps then back til it beeps this done right after startup also. otherwise there maybe something more serious going on with the chair. Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Oct 10, 2017 | Jet Health & Beauty
When plugged in lights indicate full charge,when I pull plug all lights go off,won't move this is a jet 3
Something between the batteries and the motors and joystick is interrupted. Recheck fuses and connections.
Aug 08, 2014 | Jet 3 Ultra Power Chair
How do i reset a jet 7 mobile wheelchair
did you put it in lockout accidentally? try this! turn off chair, press and hold the on button till a beep is heard, push and hold the joystick forward till a beep is heard, then pull back and hold joystick till beep is heard, turn off, and turn on. it should work now?
Sep 04, 2012 | Jet 7 Portable Power Chair
Not sure witch jazzy chair i got but the joy stick blink and keeps blinking i have tried pushing horn button twice and also turning it on and pushing joy stick forward waiting for it to beep but no beep....
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
Good Luck
mimobility
Feb 17, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Genius MaxFighter F-16U ... When i get into ANY game with Joystic support .. Jet fighters and etc ... I Pull the joystic and it wont pitch ...also it cant go right when i pull the stick to the right . ...
Hi, When you set your joystick up using the in game controlls menu try this. Try setting the controls from the bottom up I will try to explain. Lets say in the controls menu from the top it starts like this> 1)Pitch forward 2)Pitch backward 3)Roll right 4)Roll left. Start with pitch backward and pull the joystick back, It should auto input the pitch forward control. Next you would move on to roll left, It should auto input the roll right control. Get what im saying, You should only have to input one direction the other should auto input. Had the same problem with my LG extreme pro for BF2. Hope this helps good luck!
Jan 04, 2011 | Genius MaxFighter F-16U. USB PC Joystick...
The lights blink but it want move when you pwer
The chair is in lock mode. To unlock, turn on, when the lights start to scroll, push the joystick forward and keep it there until you hear the beep. When it beeps, pull it back and wait for the beep, once the beep sounds let go and listen, if you hear a high pitch beep, success. If it doesn't work the first time, just do it again. Sometimes it may not work right away but don't panic, just follow the steps again.
May 12, 2010 | Jet 3 Ultra Power Chair
Jet 3 power chair power lights just flash, no sequence of flashes
hold joystick back, press on button, move joystick forward, then let go.
Feb 17, 2010 | Jet 3 Ultra Power Chair
We have a problem with the joystick controller on my Mom's Jet 3 Ultra Pride. Is it possible to fix that?
Dec 14, 2009 | Jet 3 Ultra Power Chair
My dads wheelchair wont backup, it goes forward
you got something silly going on there. about the only thing that would cause this is a problem in the joystick controller. take it to a local store that has a joystick programmer and get it fixed for cheap.
Jul 17, 2009 | Jet 3 Ultra Power Chair
Jet 3 Ultra Power Chair Logo
73 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
