Question about Konica Minolta DiMAGE G500 Digital Camera
Need repair I have Konica, Minolta ( Dimage x50 ) Digatal camara and veiwing screen is broken after falling on the ground, I would like to know where can i send thsi camara for repair and cost to fix it.
Posted by ataboy on
  • PauloGoes Dec 10, 2007
    I have Minolta Dimage G500 and the display broken, I'd like to know where Can I send it to fix.
penanghill
  • 3 Answers
You should go to a camera repair shop in your nearest city.
I suggest that you purchase another camera, because the price of the repair will be beyond the cost to replace the camera. You might be able to buy a second hand G500 on ebay.
Posted on Jan 03, 2008
I have inserted a new sdhc 4gb card in my Dimage x 50 and have reformated but keep getting Unable to usecard
The X50 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You will need to use cards 2GB and smaller.
Jan 25, 2011 | Konica Minolta DiMAGE X50 Digital Camera
Konica minolta Dimage x50 doesn't work
Buy the AC adapter plug the camera in without any battery, if it works then its the battery,if not its the camera.
Jun 10, 2008 | Konica Minolta DiMAGE X50 Digital Camera
Dimage x50 konica minolta digital camera
If the LCD was physically cracked or broken, then yes you should be able to swap it for an undamaged one.
The cheapest option for you is to advertise or look on Ebay for an identical model - also with faults, but with an undamaged display. (maybe dropped - sold as not working)
See HERE - this is just like yours - but also has the cracked LCD. You need to search for one with a good display.
Take this "donor" apart first to see how it's assembled, then just swap the parts.
This method of repair is common for consumer electronics.
Thanks for using Fixya!. If this has provided a solution, plrease rate as such. Thanks.
Jun 05, 2008 | Konica Minolta DiMAGE X50 Digital Camera
USB AV Interface cord
Any Camera store/Computer store sell those cords make sure you take the camera with you to get the correct type of camera end connectioor but a card reader - much more versatile.
Sep 01, 2007 | Konica Minolta DiMAGE X50 Digital Camera
White lcd
the camera need to be returned to repair or replacement. To the seller if less than a year or back to Konica if more
Aug 19, 2007 | Konica Minolta DiMAGE X50 Digital Camera
White screen problem too!
We have the same problem (white screen) after my wife took it on a trip. She had it in her carry on and didn't drop it.
Apr 25, 2007 | Konica Minolta DiMAGE X50 Digital Camera
Cracked LCD
minolta and sony as well as other brand uses the same lcd panel. ( its a separate manufacturing company). try junk or surplus parts
Oct 12, 2006 | Konica Minolta DiMAGE X50 Digital Camera
White Screen
Did you find a solution for this? I'm trying to find which LCD would work on this same camera.
Jul 26, 2006 | Konica Minolta DiMAGE X50 Digital Camera
Digital minolta konica x50
You are going to need proffisional technical help in order to fix it - probably the screen will have to be replaced. :( Good Luck
Apr 30, 2006 | Konica Minolta DiMAGE X50 Digital Camera
Konica Minolta DiMAGE G500 Digital Camera Logo
111 people viewed this question
Top Konica Minolta Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Larry Stiles
Larry Stiles
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
