Select the model of your Uniden cordless phone from the list beginning at http://www.uniden.com/owners-manuals/cordless-phones/scat/cordlessphones_mnl to download a copy of the manual.
SOURCE: how to take silent mode
To turn off silent mode, press the "#" and hold down until it changes. :)
SOURCE: how do you trn a uniden D1660 cordless phone off
To exit the silent mode, press and hold # on the handset for about 5 seconds. In the future, when you set the silent mode with this press and hold routine, you can follow it by a number (1-9) to set a specific length of time for the handset to be silent. Otherwise it will stay on until you manually turn it off.
The manual for the D1660 is available from http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf .
I hope this helps.
SOURCE: how do i turn off the silent mode on a uniden
Silent Mode
You can silence the ringers on the base and all handsets for a specific period of time; the answering system answers any incoming calls without playing anything through the speaker.
With the phone in standby, press and hold # on any handset. The phone prompts you to select the number of hours (1 - 9 or Always On) that you want it to stay in silent mode.
To confirm, press # or just wait about 5 seconds. The phone turns on the answering system and displays Silent Mode On on each handset.After the selected number of hours, the phone automatically exits silent mode. To exit silent mode manually, press and hold # again.
If the phone is in silent mode and you turn off the answering system, the phone exits silent mode.
Multihandset Features To use the features in this section, you need at least 2 handsets.
Your base supports a total of 12 cordless handsets: the one that came with the base and up to 11 DCX160 accessory handsets.You must register accessory handsets to the base before using them. (Handsets that came packaged with the base are already registered.)Handsets that aren't registered display a Not Registered message. For registration instructions, see p. 18, or see the accessory handset manual.If a handset was ever registered to a base, you must reset it before it can register to a new base; see p. 18, or see the accessory handset manual.Conference Calling
When an outside call comes in, two handsets can join in a conference call with the outside caller.
To join a call that's already in progress, just press Talk/flash or SpeSpeSpeaker.To leave the conference call, hang up normally; the other handset remains connected to the call.
SOURCE: turning off silent mode on dect 6.0 cordless phone
SOURCE: how do you turn off silent mode on Uniden DECT 6.0
In standby mode pressing and holding # brings up the "Silent Mode" special feature .. unfortunately the only options are to set the time for the device to be in silent mode and no way to turn if off. The solution is supposedly to press the # key again and hold it down, but this does not work either. The only way I can manually return to not be in "Silent Mode" is to reset the base unit!!
