Question about Amerock Hardware & Accessories
2007 jetta 2t
How to change the lower hinge driver door on Jetta 2007
Posted by Daniel Tremblay on
5 Related Answers
Anonymous
SOURCE: 2006 vw jetta TDI- No power on drivers door.
WHAT IS THE RIGHT TIME TO CHANGE THE TIMMING BELT
Posted on Apr 22, 2009
Anonymous
SOURCE: How do you reset a low tire pressure warning on a 2008 Jetta?
Reset the tire pressure warning, same as you would any service issue. Insert key in ignition, hold wrench button and min button, then start engine.
Posted on Jun 08, 2009
Anonymous
SOURCE: Do you need a special tool to change the rear
yes, you need a special tool to screw the brake piston back into the caliper housing. this is do to your disc brake set up. tool is available from harbor freight at around 40 dollars.
Posted on Oct 29, 2009
Anonymous
SOURCE: 2006 vw jetta No power on drivers door.
I have the same Problem. I Simply cut into the middle of the boot between the door and body The broken wire was right there, I pulled each end out and held the wire there with a pair needle nose pliers, stripped the end with a knife and attach a mulyi-strand jumper between both ends with electrial wire twists. Leave 2" approx. then slip the boot back over them. Use # 14 Wire. A Quick reasonable fix. If brakes again repeat again. The new Haness will have the same Problem down the road.
John
Posted on Apr 07, 2010
Testimonial: "I had the problem fixed at the dealer. It was the harness They made the harness longer & it was free.. "
tunde007
Tunde Autos
  • 2382 Answers
SOURCE: how to change air filter for 2007 volkswagen
Hi, on the VW Jetta 2006 to 2009, the cabin filter is underneath the glove box so lay down on the floor and look under to see the 2 plastic screws. Access is gained by removing two plastic screws and gently pulling down a piece of foam insulation. Once the insulation is removed you can see the filter 8 inch long by 2 inch wide black plastic face plate. You must slide the face plate toward the passenger side door.
The face plate will now come off and the filter will still be inside and you will have to pull it down. Debris will come out onto the floor mat below. Insert the new cabin filter, put the face plate back up an slide toward he drivers side to lock in place. Replace the insulation, re-screw the 2 screws, and you're back in business with fresh air and clean hands besides!
Take care
Posted on Aug 10, 2010
1995 jetta iii GL door hinge
You can pry up on the door untill it lines up.yes the striker cushion can be replaced.
May 13, 2017 | 1995 Volkswagen Jetta
I need to find the fuse of my vw jetta 2.5. i want to see if the radio is burnt or not.
fuse boxes are normally down under the dash along the drivers side kick panel, or along the outer dash board on the drivers side with the door open,,
Aug 26, 2011 | 2007 Volkswagen Jetta 2.5 Sedan
Squeaky Door....embarrasing!
1: White Lithium Grease
2: Silicone Grease
Either will work just as well, though lithium may be easier to find at the local auto-parts store...and a bit cheaper.
* They silicone comes in a spray which makes it easier to get to the hinges.
In a pinch, a can of Liquid Wrench will cure the noise, but it doesn't offer the long-term benefits of grease.
** There are 2 sets of hinges, upper and lower...and be sure to get the rollers on the guide arms.
***Don't forget to VOTE for the guys who take an interest in helping!
Jun 19, 2010 | 2000 Volkswagen Jetta TDI
Windshield wipers on 2007 VW jetta not swiping
wiper gears may be broken, got to junk yard and buy motor and gear assembly for windshield wipers, should only take an hour to change out.
Feb 15, 2010 | 2007 Volkswagen Jetta 2.5 Sedan
Hi, I just bought a wonderful 1994 Jetta. Everything works great except that the alarm light on the drivers side sill does not flash (which makes me think the bulb needs to be replaced or someone disabled...
Most likely a bad connection. I have a 94 jetta and have been fighting bad connections and burned wire traces on dashboard pc board. Yours could be broken wire in the boot by the door hinge.
Feb 02, 2010 | 1994 Volkswagen Jetta
2005 jetta drivers side window only will open if door is open.
I'd look for a bad wire in loom that runs from pillar to door at hinge area.
Jul 22, 2009 | 2006 Volkswagen Jetta
Jetta volkswagen 2007
I also have a 07 Jetta and that light comes on all the time, to resolve this, you have to make sure all your tires are at their psi specs, I believe its like 32 psi. Check your owners manual or driver door to make sure. Dont worry, it gets irritating but that light comes on all the time.
Oct 13, 2008 | 2007 Volkswagen Jetta 2.5 Sedan
Horn blowing and car wont start
Same problem on 98 Jetta at about 9 yrs of age.  Wiring harness was an expensive job.  Dealer replaced all wires going to doors so that alarm isn't mistakenly triggered by opening doors.  Dealer offered to remove alarm for a few hundred dollars, but couldn't assure us that the key fob would still open the door locks.  Who wants to give up power locks? My hunch is that wire in driver's door breaks with flexing over 9 years.  Could consider replacing short stretches of wire in hinge of drivers door if you're handy with a soldering iron.
Jun 14, 2008 | 1998 Volkswagen Jetta
Hardware & Accessories Logo
49 people viewed this question
Top Amerock Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an Amerock Hardware and Accessory Expert? Answer questions, earn points and help others
