The refrigerator just started making a continuous sound that is coming from freezer area, except that stops when you open the refrigerator door. Does not stop if you open the freezer.
SOURCE: Kenmore cold spot refrigerator freezer
wow you have power to the unit what about the temp control ? is it turned up?? if so is it closed(calling for cooling?) that is the place to start you can jumper it after yo unplug it to see if you dont have a meter
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck [email protected]
SOURCE: Refrigerator/freezer has stopped cooling
Sounds like you need a new relay for the compressor. Unplug from wall and check the compressor see if realy that is attached to pins on compressor, is burnt.
SOURCE: Our kenmore elite bottom freezer is making a loud
Turned off the fridge, emptied the Freezer, used a blow dryer for 20-30 minutes, to melt ice that had built up in vents at rear of freezer.
Cleaned the freezer and reloaded...no hum..at least for now.
Testimonial: "It worked for me."
