Question about Cobra 148 GTL 120-Channels Base CB Radio
Tx red light is use to show what
All lights come on when you press the mike except the tx light could the buld be out or its not transmitting
Mike Charette
    Genius:
  • Cobra Master
  • 1,847 Answers
When you are not talking the light should be an aqua / green color.When you transmit it should turn red. if you see two red lights your antenna is out of match.As for your radio not get out you have to get a friend to listen on another radio and he will tell you if its working or not.
Posted on Jul 30, 2014
5 Related Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: RED TX and ANT light, Cobra 29
Your post of 2 lights; 1 is to indicate that you are transmitting when keying the mic is normal. The 2nd indicating an antenna warning (or SWR) should be corrected. You are right in starting with the coaxial cable which of course would include the PL259 connector. Verify that there are no breaks, over-bended loop, exposed ground/shield and that the solder of the center wire as well as the braided shield/ground is in order.
If it is a mobile setup, further verify that the antenna mount (except when magnetic) is properly grounded to the body of the vehicle and free from rust/corrosion. In some instances, it is the antenna itself that need checking or even possibly replacement.
Alternately, if the needle doesn't swing to the right side of the meter when the mic is keyed, it is possible that your finals (2SC1306) needs replacement.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 06, 2007
Anonymous
  • 19 Answers
SOURCE: Cobra 29GTL Won't Transmit
if the red ant light comes on this means that you have antenna trouble either in the antenna itself or the coax but this should not have anything to do with the radio not transmitting. it sounds to me that you have a bad audio chip or a bad power output transistor. in either case you should really take it to a cb shop and let the professionals solve your problem, good luck!!
Posted on Aug 17, 2007
Don Reiman
  • 773 Answers
SOURCE: Cobra 29LTD CHROME low tx no mod, rx good low Vol, talkback good
1 why would you change the finals?? Have you checked you antenna? How are your SWR's? Crappy antenna's cause a lot of problems.
Use an external meter to see what the SWR is, and see what the output is PEP. If its low, then there is something wrong. If it is High, change the mic and turn up the dynamic all the way.
Next. Have you been messing around in there?? Tryin to get more wattage? You turned VR4? If you thought you were turning it up by turning it all the way to the right, you turned it all the way down. Turn it all the way to the left.
Posted on Jun 17, 2009
Anonymous
  • 6 Answers
SOURCE: no transmit on cobra 29
Check your coaxe and the antena
Posted on Aug 30, 2009
Anonymous
SOURCE: when i key up the mike the tx/rx light and the ant
your swr setting are off wack fix your swr
Posted on Oct 09, 2009
I have an cobra 148 gtl no transmit
If theres no carrier its either the finals or driver. If theres no audio its the white wire in the plug that screws into the radio..its either broke or most likely come unsoldered. It keys but no audio.
Mar 05, 2015 | Cobra Radio Communications
Why does the tx light flash on my ftdx5000?
There are several things that can cause this.
1. Powered on with the mike keyed
2. Accessories plugged in the back
3. Power interrupted
To fix this leave the power on, UNPLUG the unit and wait for it to power drain. Turn the unit off plug it back in. If that does not take care of it, take the microphone off and any accessories and try again.
Jun 15, 2014 | Yaesu FTDX5000 HF base station transceiver
Why does my kenwood TH-K2 fm transceiver will not transmit
Users Manual (download if you don't have it)
TX I
NHIBIT
You can inhibit the transmission to prevent unauthorized
individuals from transmitting, or to eliminate accidental
transmissions while carrying the transceiver.
1 Press [MENU].
2 Turn the Tuning control to select Menu No. 25 (TXI).
3 Press [MENU].
4 Turn the Tuning control to select "ON".
5 Press [MENU] to store the setting or [PTT] to cancel.
"TX INH" appears and an error beep sounds if the
transceiver tries to transmit while TX Inhibit is ON
May 11, 2014 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Indicator light doesnt work and the meter doesnt work.
If your TX (Transmit) meter does not work at all, it might or might not be a faulty press-to-talk switch, or faulty wiring. More often, it's the final amplifier stage that's defective if you don't have a carrier (signal) when you key the mike. That will require a qualified Tech to make those repairs. I'm basing this on my experience as a Communications Technician since my Navy days and CB Dealer since the mid 1970s. Thanks
Aug 25, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
COBRA 21 GTL NO MODULATION NO RX. BUT IT WILL TX AT 3 WHATTS.I HAVE TRIED 3 DIFFERENT.MIC ON THIS RADIO CAN YOU HELP ME
That's usually a defective amc stage that produces RX audio and TX modulation. It's an integrated circuit that will require a tech fixing it. You will have a transmitted carrier with no modulation, and no sound in your speaker. However, make sure you have a good mike plugged in first, and substitute a known good mike to verify it's not the mike.
Jul 30, 2010 | Radio Communications
I have a Cobra 18 wx st. I am not able to transmit anything on it. I have checked the antenna cables and and all external connections. I receive all the wb just fine but the CB gives me nothing. I tried a...
That's usually a defective amc stage that produces RX audio and TX modulation. It's an integrated circuit that will require a tech fixing it. You will have a transmitted carrier with no modulation, and no sound in your speaker. However, make sure you have a good mike plugged in first, and substitute a known good mike to verify it's not the mike. With the WX band working, the above may not apply.
See if you have a carrier...signal going out, but no modulation. Get your Tech to check the mike wiring/circuitry inside the radio, also.
Jul 06, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
My galaxy 959 cb radio wil not put out any transmit
Based on your post of no transmit, a couple of possibilities:
1. defective microphone or cord or PTT switch (the red TX light does not come on when pressed);
2. TX light comes on but no output, defective finals and/or drivers. These are the transistors screwed to the chassis of the radio very near the antenna terminal;
3. defective regulator IC that provides the TX B+;
5. insufficient amperage from you power supply;
6. too high SWR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Thank you for using FixYa.
Feb 16, 2008 | Radio Communications
Dec 06, 2007 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 148 GTL 120-Channels Base CB Radio Logo
89 people viewed this question
Top Cobra Radio Communications Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
