Question about Doro PhoneEasy Cell Phones
How to set alert for incoming texts
Just a very quite sound when I get a text,would like it louder and longer.volume is turned up.
dabade
    New Friend:
  • 27 Answers
Don't know that phone model, but usually "notifications" and "media" have separate volume settings. Try looking in settings.
Posted on Jul 22, 2014
5 Related Answers
Anonymous
  • 151 Answers
SOURCE: LG Secret SMS text alerts sounding only once
In the settings change the interval to continuous.
Posted on Dec 28, 2008
Anonymous
  • 5 Answers
SOURCE: Volume Problem Motorola w385
perhaps you may try if you haven't already to go into settings>sounds>and from there you will be able to see what you have your ringer volumes and other stuff set up. be sure to check ringtone type, volume, and alert. This should be able to help you. Then it depends on What ringtone you have set for them. I created a voice note and used it as a ringtone and for some reason it stopped working and now when my mama calls it just beeps letting me know I missed a call. Even though the other voice notes work fine as ringtones. I haven't changed it yet.
Posted on Feb 16, 2009
Anonymous
SOURCE: Text message tone volume, LG KP500, Cookie
Go to Profiles, and choose a Customized Profile. Rename it to whatever you prefer. In this profile you can select your ring tone, message tone, volume, etc. I only had to do this once, and everything worked perfectly!
Posted on Jun 11, 2009
270rexton
270rexton
  • 782 Answers
SOURCE: no text message sound alert. it still rings out
Go to settings and check "Event notification".
Posted on Jul 13, 2009
Anonymous
  • 97 Answers
SOURCE: How can I set repeat incoming text alert tone till text is read.
this should be in sound setting its absending you want set it on
Posted on Aug 14, 2009
How do i get sound to work for recieving text messages
Depends on the phone, but on iPhone there is a very small lever on the top left edge above the volume UP button.
You should also check Settings - Sounds - Text Messages
COMMENT below my name with make and model.
Aug 02, 2016 | Cell Phones
Need louder incoming text notification as I am hard of hearing.
Check manual for volume settings for incoming text notification.
Nov 08, 2015 | Cell Phones
I have a Motorola C118 phone. I've had it for quite a few years, but over the past few months the ring volume for incoming texts and calls has become very quiet and I often miss texts or calls. The...
Find the speaker on the phone and check that it is not plugged part way with dirt/dust....
other then that there is nothing you can do... the problem is internal...
heatman101
Jun 27, 2011 | Motorola Mobility C118 Cellular Phone
My sidekick lx text alert tone does not work. the sidekick does not vibrate or make a sound when i receive a text.
This most likely has to do with the sound profile that you currently have set. Go into the sound options, see if there is a detailed option available to increase/decrease the ring volume or vibration.
Some phones have the option to turn on an alert and vibration for text/incoming call.s
May 02, 2011 | Cell Phones
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
How do i turn on the text notifaction. i dont
- Applications
- Sounds
- Set Ring Tones/Alerts
- Messages
- SMS
- Select Tone, Volume, LED, Vibrate, etc
- Press BB Menu Button
- Save
User Guide Here: http://docs.blackberry.com/en/smartphone_users/deliverables/2970/userguide_bb9000_umts.pdf
Jan 09, 2010 | RIM BlackBerry Bold 9000 Smartphone
Aug 14, 2009 | Cell Phones
Text Message alert???
In order to use tones other than the presets for text messages, you have to put new .WAV files on your phone. Any 8bit .WAV file will work; just connect with ActiveSync and navigate to your /Windows directory on your phone, and place the files there. You will then be able to use them as text message alert tones.
Aug 29, 2007 | Audiovox PPC 6700
Cell Phones Logo
67 people viewed this question
Top Doro Cell Phones Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Doro Cell Phone Expert? Answer questions, earn points and help others
