Question about Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer
My B&S power washer won't stay running - it starts then quits almost immediately. It has oil, it's getting air, it's getting spark, I've cleaned the gas tank and fuel fliter, and put in nice fresh fuel. I've also cleaned the carb - twice. If I squirt a little starter fluid into the carb it will start, run for a second and then die.
Posted by Michael Fodroci on
Patrick
    New Friend:
On the Carb there are usually two needle valves, doing one at a time and carefully counting half turns. Using a small screwdriver start turning clockwise one of the screws in and count how many half turns you turn until tight. Might be 1 1/2 (half turns) to 3 1/2 (half turns) After it is tight reverse the screw and spring and remove it. Blow out the hole with a stray or air pump or wd40 spray can with straw tip. Reinstall until tight then open the amount of half turn you recorded. Do the same with the other needle valve.
Posted on Jul 21, 2014
3 Related Answers
Ben Dover
  • 1111 Answers
SOURCE: just bought a new Briggs Stratton 6 75 pressure
assuming you tried choking it when you tried to start it, verifiy its getting gas,if not tap lightly on the bowl of carburator. if it is getting gas, check for spark
Posted on Jun 20, 2009
Anonymous
SOURCE: I have a Craftsman 2700 psi pressure washer with a
Here is the long answer with everything we learned while using a power washer twice a day for years::
It sounds like could be one of the problems listed below or a combination of those things.
1) The exhaust is partially blocked. Check the screen covering exhaust port for carbon and dirt build-up. High-speed exhaust air must pass freely. We finally broke the exhaust screen out with a screwdriver to get our machine going one day.
2) Gas is not flowing freely to carburetor > under gas tank, find the rubber hose connected to carburetor. Pull off rubber hose and make sure gas flows freely. You can use this hose to drain gas tank of old gas ... and then put in fresh gas.
3) Carburetor is partially gummed up and engine cuts off when gas flow slows down. Buy some gum out, and then don't store power washer with gasoline in the tank. Or put additive in gas when storing machine.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or the machine would die. We still use the machine at 2/3 throttle, and then start it each time using WD-40 as described below.
5) Dirty air filter that won't let engine breath enough air to keep up with combustion. Take off air filter and see if problem persists.
6) The spark coil is going bad?? Change spark plug to see if problem persists. Is spark plug wire pushed all the way onto the spark plug?
Now the nitty gritty: we're gonna start that thing right now
7) Take off air filter. Spray WD-40 directly into carburetor. Yes, we use WD-40 every time to start my power washer, and we use the washer twice a week.
Spray in the WD-40, Pull the engine cord. The engine will fire on WD-40. Guaranteed.
Once it starts, keep spraying WD-40 directly into carburetor to keep engine going.
If engine will not fire and keep going on WD-40, then your spark is suspect.
If your engine fires and runs on WD-40 but dies without it, then your gas supply or carburetor are suspect
8) Carburetor problem >>> try Gum out >>> and then take machine to small engine repair shop
9) Spark ... take out spark plug. Put spark wire back on. Hold spark plug by spark wire. Touch metal threads of spark plug to metal opening where plug came out. Metal to metal. Pull back start cord and look for spark between the metal.
If you have no spark, then spark coil is bad >>> take machine to small engine repair shop
Let us know how it comes out!!
Posted on Oct 22, 2010
cool78259
ruben sanchez
  • 228 Answers
SOURCE: we have a 6.25 /Briggs & Straton we have cleaned
You should have two fuel lines going from the carb to the tank, one has a filter,
make sure both lines are good without any breaks or cracks. if the filter is dirty
you may need to replace it. you can fish it out of the gas tank by making a hook
on a wired coat hanger, try to remove the filter and put the line back in the tank
make sure they are both submerged, if it runs just replace the filter, good luck!
Posted on Jun 26, 2011
My mower won't start
try running it with the gas cap loose the vent might be plugged
Apr 13, 2012 | Garden
Briggs & Stratton motor
try a new coil
Mar 23, 2012 | Garden
Pressure washer won't start. It has gas, oil and I turned the switch to turtle and to rabbit position. Does it matter if water is on first or not? It won't start either way.
Turn the water on, hold trigger down and let water run thru the hose to prime the air out of the hose. If it still will not start check the spark plug and clean it or replace it. A bad spark plug will keep it from starting
Aug 22, 2011 | Briggs Stratton 020273 Elite Series...
I have a Toro 4 cycle gas trimmer that won't stay running. Starts, then sputters, then dies. I've changed the oil, drained fuel & put in new fuel.
check to make sure the air filter and the fuel screen are clean, the screen is the little white plastic piece on the end of the hose in the tank. if it is still sputtering try cleaning the bell out on the carb. it is the little metal cylinder on the bottom of the carb where it holds the fuel until it evaporates into the engine if it gets clogged the engine will not run properly.
Jun 30, 2011 | Garden
Engine on powerwasher starts but quits running after approx 10 seconds. Engine oil changed, oil is full & tried choke in various positions. Also has fresh fuel in tank. What else can I do
try cleaning the carb that ethanol plays havoc on these small engines if it is not a premix oil and gas unit add a little 2 cycle engine oil to the gas will keep the carbon builup to a minimum not to much it will gunk up your spark plug take the carb apart and clean it with carb cleaner or deisellet dry check your spark plug make sure it is clean and ok that is where I would start
Jun 27, 2011 | Craftsman 2700 PSI Briggs Stratton...
1998 GMC Savana conversion van - It starts right up and immediately dies, repeatedly and randomly. Sometimes it won't start for days. Then poof, starts right up. It turns over fine, it starts fine. The...
It won't die when pulling the relay because it has another power path to the fuel pump through the oil pressure switch . Fuel Pump Electrical Circuits Description and Operation watch this video on fuel pump control , shows chrysler first , ford ,then gm . wait for gm an he explains the oil pressure switch . Plus when it won't start ,don't guess or theorize ! Test what's missing ? check for spark , no spark check ignition system , coil's , ignition module , crank sensor etc... has spark ,do a fuel pressure test etc... don't think computer , when it won't start does the check engine light come on with the key on run not start . If light is lit ,nothing wrong with the cumputer . If want to fix cars you really should take some automotive classes . Test don't guess .Watch some other videos crank no start videos etc...
Mar 02, 2017 | 1998 GMC Savana
Hi. I have a Briggs & Stratton 2800PSI gas pressure washer. I can get it to start, but after about 5 min, then it quits. I have cleaned the carb, change oil, changed plug, new gas, cleaned/checked...
if it wont start, check for spark.how you do that,ok take the spark plug wire out put it close to the sparkplug(use some gloves or something to insulate your self from get electric shot from the spark) find some one who pull the start rope, if you dont see any spark between wire and spark plug, tehre its not spark ,it will never start.you will have to remove the start recoil on the botton is like a damper whitch will have to be remove also ,on botton of it its like a coil whitch with the rotation of the damper when you pull the starter rope provoke the spark and send it to spark plug along with the gas combution get the engine started.that coil some time goes bad and have to be change.if you have electric starter. check the starter also.good luck
May 30, 2011 | Briggs & Stratton Prosumer 20324 Gas...
My 5.5 honda engine on my lawnmower will start but wont stay running already cleaned the carb out didnt help there is no restrictions in the fuel lines im lost please help
it sounds like a fuel problem.
first drian fuel out of tank.
i know you have already cleaned the carby but dis assemble carby and clean with carby cleaner.
re assemble carby & fill tank with fresh fuel.
also clean air filter & check oil level & check spark plug,if the spark plug is black and the tip is blocked with oil build up, then replace.
Oct 22, 2010 | Honda Garden
My troy built 2200 pressure washer was running fine but then shut off instantly I then noticed it had low oil I filled it but now it won't start
Pressure washer takes oil in two places:
Pump oil is 20-30 weight SAE non detergent and comes half way up/ do not fill more than 1/2 way
Engine oil is 10W30 and comes half way up dip stick
IF you overfilled the oil >>> DO NOT turn power washer on it's side or upside down to drain oil >>> because engine oil will fill carburetor
When engine won't start
We pull off air filter so we have direct access to carburetor
Spray WD-40 into carburetor while starting
The engine will fire on the WD-40
You can keep spraying WD-40 into carburetor to keep engine running while moving choke to see if engine will run on it's own
Squeeze gun trigger so water comes out gun and pump pressure doesn't stop engine
If engine will not fire on WD-40
Spark is suspect
Your spark plug gets power from ignition coil
If coil is bad you get no spark > and coil needs needs replacement
Take out spark plug, clean it with WD-40 and use a bit of sandpaper in the spark gap
Put spark wire back on plug
Touch threads of spark plug to metal part of engine > pull cord and look for sparking between spark plug and engine
If you do NOT have any sparking, then coil is bad
If you HAVE spark, then your spark plug needs cleaning or replacement
If engine fires on WD-40 but will not keep running
Then either fuel or carburetor are suspect
Loosen hex nut on fuel filter located below gas tank >> if fuel flows, then re-tighten hex
Next, pull off rubber hose connected to carburetor to see if fuel flows to carburetor
If fuel is flowing to carburetor, then the carburetor is suspect.
Small engine repair shop will have carburetor cleaners
Check exhaust
There is a screen over exhaust
Make sure it is clean of carbon build-up > Use WD-40
Change air filter
Oct 12, 2010 | Briggs & Stratton Garden
Engine starts but immediately stops
Engine starts but stalls out. Plug cleaned and air filter removed.
May 25, 2010 | Toro Lawn Mower With Toro Power Tools
Briggs Stratton 020273 Elite Series Portable Gas Pressure Washer Logo
233 people viewed this question
Top Briggs Garden Experts
Mike
Marvin
Marvin
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
