Why cant I receive text off certain numbers but same numbers can receive text also can hear my own voice instead of callers quite a lot
SOURCE: Cant recieve text messages
Yes i have the Sprint LG Rumor and none of my texts are coming in. I dont think it is a device problem. At first my text messages wouldnt send at all and then i restarted my phone and they started to send but i cant recieve any text messages. Its been like this for the past hour. My Girlfriends texts are not coming in, as well as my sisters. I texted my sisters phone and her texts didnt come either. Its really frustrating me and id like to have it fixed.
SOURCE: Is there a way to block text messages from a #?
if ur phone supports software then u can use,,,,
1. SMS spam manager
2. Advanced call manager
3. Black list pro
& many others.....
if the software requires license key u can write in FIxya,,,,,, i will help u
Just VOTE me,,,,,,,,,,
[email protected]
SOURCE: t9 texting numbers
From "Best Solution".........(quote) "alright type the word that you want (ie.Hey) it will show up as 439. then go through the words until you find "Hey" then hit space twice and do it over again. after a couple times it should pop up as "hey" first instead of 439."......My Comment would be that this absolutely works!!!! YEAH!!! I've had this problem for so very long and no one at the AT&T store could help.....but.....the longer you've had the problem the more times you have to type and change the word. My phone was selecting 843 for the word "the"....it had been going on for months....so, it took about about 60 times typing and changing and spacing before "the" came up as the first choice word
SOURCE: i cant recieve calls or make any calls from my cell phone
Hello:
You need to restore factory settings of your k800i . your phone default code is 0000, go to setting then select restore setting or factory setting and enter code 0000 .
If this solution is helpful please click a thumbs-up rating below.
good luck .
SOURCE: i may have blocked a
Normally different phone also has different settings. In your case I suggest you go to the menu phone book setting of your phone. If you can see the option there try to click it, and check if you can see some names that you block before. Then just click the option under the name and unblock it. I hope it helps.
