Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder Logo
Question about Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
I have an error code HDD ERR display on my Panasonic DMR-EX75EB
5 Related Answers
Anonymous
  • 13 Answers
SOURCE: panasonic dmr ex75
HDD ERR is quite a serious error, as it means there is a hardware problem with the internal disk drive. You could try switching off the unit and disconnecting the mains cable overnight, and trying again, but really this will need to be a call to an engineer.
If your unit is still in warranty call them now to arrange a fix. To find your local warranty centre, go to your regional Panasonic website, and look under Customer Support
Posted on Dec 30, 2007
Anonymous
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
Anonymous
  • 55 Answers
SOURCE: PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Posted on Apr 22, 2009
Anonymous
SOURCE: PANASONIC DMR-EX768 DISPLAYS MESSAGE EXT-L
Hopefully you will have figured this out by now but you have accidentally turned on the external link function (used to automatically record from a sky box or similar) - simply press the ext-l button on the remote (second row from the bottom of the remote, 3rd button from left) to turn it off again and everything will work normally once more.
Posted on Apr 14, 2010
Demonic-2011
Demonic-2011
  • 513 Answers
SOURCE: My DMR EX75EB it fails
This is one of several error codes generated by the main microprocessor IC which are tripped by corruption, preventing proper operation and which may require the processor to be reset (where practical) or replaced.
The U81 and U80 codes don't mean anything in particular because the corruption error could be caused by a number of different reasons. It does not point to any specific one fault. This is where the confusion sets in as to the origin of the 'error code' in any device.
U81 means (in technical terms) 'microprocessor communication malfunction' on the universal asynchronous receiver/transmitter' or 'microprocessor feedback information error'.
This is not something the user should undertake to repair themselves; it should really go to an authorised Panasonic repair centre. The cost depends on the parts used and the labour, however, it is not unfixable. You can always get a quote on this and a second opinion, then decide for yourself if it is economical or not.
I posted this 'advice' for this model previously. The DMR-EX75 and DMR-EX85 are prone to U81 - which is a common error code.
Posted on Mar 14, 2011
Testimonial: "Many thanks for your input, after speaking to Panasonic, you are correct, they tell me it would cost approx £100 to repair so its a bin job:-("
What does U81 mean
It could mean there is a fault on one of the circuit boards. See
http://www.avforums.com/threads/panasonic-dmr-ex75-85-u81-error-repaired-solved.1486954/
When your HDD (Hard Disk Drive) does not work, the computer would like a recovery disk, or with windows the Windows disk will do. If only the OS has some damage windows will see so and ask, should I recover the OS already on the HDD. If you choose that opting, the CD will try to recover everything.
If your HDD is really defect and can't be recovered by the OS, toy have to replace the drive and setup the computer again. You have lost all data and all program m's on the HDD, so I hope you have a backup of at least all your data.
Good luck
Fault A2
Are you SURE it's a fault code, and not the selected AV input? (A1, A2 or A3?
Press the Input Select button on the remote to cycle between AV inputs and Freeview channels
8helpful
My DMR EX75EB it fails to operate and a code of U81 comes up.
3helpful
Panasonic DVD recorder won't recognize any disk inserted in tray
I am just wondering if you found the solution to this problem as it has happened to ours.
Regards
2answers
Read failure o DVDs on Panasonic DMR-EX75
You need a lens cleaner to clean the lens of ur DVD recorder..
Time change
I pressed all the buttons on the remote control untill I found the right ones. It was trial and error.
2helpful
Panasonic dmr ex75
Top Panasonic Televison & Video Experts
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
