Where is the place i plug my charging cord into on the rino 650 garmin
You need to use the AC adapter or specific vehicle charging cable to charge the rino series. They plug into a different port on the unit.
Posted on Jul 23, 2014
SOURCE: Garmin NUVI 660 power problem.
To charge a nuvi, use one of the following methods:
Please note: All of the nuvi series will come with a suction cup mount and vehicle power cable to charge the nuvi. However, only some of the nuvi models will come with an AC power cable and/or USB cable. If they did not come with the nuvi, they would be optional cables and would be a separate purchase. Garmin only recommends using an AC power charge that is purchased from Garmin. Third party power cables may not charge the nuvi. These cables may be purchased from Garmin or Garmin's dealers.
Posted on Oct 11, 2008
SOURCE: I have a Garmin 200. It will not charge . If I
its a typical problem with alot of gps that the power port(usb)have come loose. sometimes they can be resolder, while most of the time they rip the tracers off the board, making a repair impractical.
you can take the unit apart and examine it under a magnifier to look and make sure the tracers are not damaged or its just needs resoldered.
Posted on Aug 19, 2009
SOURCE: Electrical burn Garmin Rino
Send it to Garmin with a letter detailing what you did and ask for an estimate of repair.
Posted on May 20, 2010
SOURCE: When I plug my Garmin
The fuse may have blown in the charger. THe fuse is in the plug that goes into the cigarette lighter socket. Unscrew the ring near the tip of the socket being careful not to lose the tip. The socket comes apart when you remove the ring. Replace the fuse and it should be ok.
You can charge the satnav from your computer but it will take around 8 hours, twice as long as the car charger. Just connect it to your computer and turn both on to charge it.
Posted on Jun 18, 2011
SOURCE: My garmin rino hcx won't upload satelites
Try performing a factory reset.
Be sure to save your favorites, routes, and waypoints before doing the reset as these will be deleted.
The factory reset is done with unit OFF.
Press and hold PAGE button and ENTER
button and while holding the buttons turn ON the unit.
Reset is complete.
Posted on Jan 19, 2012
