SOURCE: 2610 won't print
By self-test, I assume you are doing that manually on the printer. drivers downloaded/installed? right click on my computer, left click on properties, click on hardware, and then click on device manager. is there a yellow question mark by print drivers? If so, then need to load them from the internet or from your installation disk.
SOURCE: printing problems
SOURCE: 2610 xi HP printer will not print, copy or print a FAX
I recently moved my computer and now my printer dosen't work. I have checked the connections and they seem to all be fine.
SOURCE: hp 2610 will not print black even with new cartridge. HELP
Try cleaning the gold contacts on cart first, with distilled water. Let dry and try again.
If not, try this one
1.Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Inkypete
SOURCE: hp 7110 Printer erro
I'm not sure you specified the correct printer. The 7110 printhead is not pentagonal. Is your printer the 7110 all-in-one?
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts or possible fault of the printing head.
