My GE TFX30PRY side by side has water freezed on the bottom of the freezer. What can cause the problem ? Thank you.
You have a clogged drain system in the freezer, as the unit will defrost daily, the water can't leave the freezer properly and the water collects. You need to de-ice the freezer and clean out the drain tube at the bottom of the freezer section under the evaporator. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
SOURCE: ge profile water/ice fridge side under bottom drawer
take out the back panel in frzzer side use a steamer to clean out your drain hole
SOURCE: GE profile bottom freezer refrigerator clicking
Your relay on the compressor is bad. It is called a PTC relay they are known to go out.
First be sure to unplug frig. Remove the cardboard cover that covers
most backs of the units. Remove the plastic cover that is on the
side of compressor. It is held on with a metal clip. Now you should be
able to see the relay pry the relay straight off. note the wiring and
position of relay. Only three prongs on compressor. Go to a parts house
for appliance's and with your make and model number should be able to
get a new one. Let me know if you need any more help. ken
SOURCE: I have ice at the bottom of my side by side GE
Remove the bottom freezer crisper , and at the bottom of the panel ( it looks like you have a drain trough cover which has to be removed ) , if its not frozen over with ice , youll see a drain hole . Use a hair dryer to defrost the drain until you see the hole . Then continue defrosting the hole until water will flow thru it . Sometimes , hot water helps to thaw the drain . When thawed , use a small hose inserted into the drain , and blow thru it , to clear out any debris in the line .
SOURCE: MY GE TFX30PRY still cools but doesn't get
Since you say that it still cools, you need to start out with a thorough cleaning of the condenser grill. If it the air flow is blocked or the condenser grill is extremely dirty or clogged with pet hair, then the unit won't be able to dispel the heat buildup cause by the coolant running through the compressor.
I have found that if you use an air compressor blowing from the rear and a vacuum from the front works pretty good.
