Question about Redhead Pursuit (18-36x50)
How can I purchase a spotting scope manual for a Redhead Pursuit spotting scope?
I purchased a new redhead spotting scope and found that NO instruction manual or any paper work came with it. I really don't feel like making another 150 mile round trip just for paper work.
Bob Sloan
  • 2,013 Answers
Call your nearest Bass Pro shop. They may be able to arrange for you to get a manual.
Posted on Jul 20, 2014
2 Related Answers
Anonymous
SOURCE: parts list for redhead ascent
CALLED BASS PRO SHOP , THEY EMAILED PARTS LIST
Posted on May 14, 2009
Adrian762
Adrian Ahrens
  • 425 Answers
SOURCE: Where do I get a eye lens for Redhead outlook
Find an Optics outlet that deals in this brand. Or a very good optics person will be able to fix it regardless.
Posted on Feb 14, 2010
Why won't my safe open its impossible to get it to lock no matter what I do it stays open
It sounds like it needs a new battery. If you comment to this post with a make and model I will see what I can find.
Jan 24, 2016 | Locks & Locksmithing
I have a redhead pursuit bore sighter when i try to bore sight my grand sons 22 it does non seat very tight when you attach it to the bore just a slight movement it does a 360
I have the same bore sighter and to fix your problem is easy. Wrap some TEFLON TTAPE (plumbers tape), it'll tighten it. Hope it solves your problem.
Sep 23, 2011 | Sport & Outdoor - Others
We need 2 know what 4 m o a means
MOA is the abbreviation for Minute of Angle, which measures 1/60 of 1 degree. If you want all the technical jargon and math that involves, this link explains it all: http://en.wikipedia.org/wiki/Minute_of_angle
But when you're talking about rifle scopes, here's what you need to know:
Adjusting the angle of your scope by 1 MOA will change the point of impact by about 1 inch at a distance of 100 yards. So 4 MOA is roughly 4 inches over on an object viewed at 100 yards.
Usually, the windage and elevation adjustments on a scope will be about 1/4 MOA, or about a 0.25 inch change over 100 yards.
Nov 22, 2010 | Redhead Pursuit (18-36x50)
Good Morning Sir; I Want The Bud Red Ahead Activation Code Please!
Hello Sir !
bud redhead activation:
Serial : 1F10-11F2-0F16-04A2-8EC7-81F4-B1C5-5727
Jul 12, 2010 | Video Game Consoles & Games
How to set up a redhead red dot pursuit deluxe
You must have the correct rings for your base. If the scope has rimfire dovetail rings already attached, it should be easy. Remove the 4 setscrews on the top of the receiver, install the dovetail mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10 IN/LBS! Otherwise you may strip the threads in the receiver!).Loosen the clamps, place the scope on the dovetail mount and tighten snugly.
If it has weaver mounts, you will need to install a weaver rail to your receiver. Remove the 4 setscrews on the top of the receiver, install the weaver mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10 IN/LBS! Otherwise you may strip the threads in the receiver!). Install the rings in the weaver slots, tighten snugly.
Go Here:
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
for info on how to zero your red-dot after you have it mounted.
Apr 17, 2010 | Cabela's Optics
I need a replacement rubber eye guard for the eye piece on my read head spotting scope. Any ideas?
I'm looking for a replacement eye guard for my finder scope and this place looks first class!
http://www.anchoroptics.com/catalog/product.cfm?id=195
Eric in NZ
Dec 31, 2009 | Redhead Optics
Where do I get a eye lens for Redhead outlook spotting scope?
Jun 09, 2009 | Redhead Zoom Spotting Scopes - Choose Size...
Redhead Pursuit (18-36x50) Logo
470 people viewed this question
Top Redhead Optics Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Redhead Optic Expert? Answer questions, earn points and help others
