Ovens Logo
fussy Posted on Jul 20, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oven door will not open - Ovens
Stephen Potts
Level 3:
  • Master 447 Answers
  • Posted on Sep 08, 2014
Stephen Potts
Master
Level 3:
Answers
447
Questions
Helped
130608
Points
1158
Have you cleaned the oven with clean cycle? If you did, or even if you haven't, push clean lever to clean, then push it to finish with some force. The self clean is not letting you open the door. It locks oven door so you can't open it.
2answers
My oven is saying unlock door after self cleaning but the door is open
It's likely that the door switch has failed, or stuck in the depressed position from grease or your oven cleaner spray solution. To correct this problem, remove the door switch and inspect with a multimeter for continuity connection.
Dec 22, 2013 • Ovens
3helpful
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Have a maytag super capacity plus oven i tried cleaning the oven now the door will not open and it shows f9 on the front
Had the same problem. How I fixed it, was by using a very thin, and I mean really thin, flat tip screw driver and a flash light. Unplug the stove. Use the flash light to look at the very top of the oven door. You should see in the air vent slats a silver hook. Use the screw driver to go through the vent slats and push the lock open. Now, you should be able to open your door. But we arent done yet. With the door open, plug the stove back in. Close the door and wait for the F9 to flash. Now open your door, and on the right side you should see a tiny peg sticking out on the open oven. Its for the light to come on when the oven door is open and also to let the oven know the door is ajar. Push it in and wait. The door latch circuit should reset like normal, and you will see the latch move back into its normal open position. Which resets the F9 error and allows you once again to use your oven like normal.
Kenmore oven 41775790 locked door
after self cleaning with the racks still in oven, i cannot get the oven door open, locked down, does this have something to do with the racks left in oven during cleaning. what do i need to do
8helpful
6answers
Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Oven door stuck
To open the door, raise the oven top and use a a flat head screwdriver to open the lock manually.
The door will still lock itself when you close it, so this is only usefull to get your food out.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
