Gold Medal 2003 Whiz Bang Popcorn Maker Logo
Question about Gold Medal 2003 Whiz Bang Popcorn Maker
Popcorn maker worked great for a matinee then for the evening show the kettle no longer heated up
Yellow wire to the kettle has 118 volts black wire has 63 volts. The Orange indicator light does not completely extinguish when the kettle he's t is turned off
Posted by Michael Trent Jensen... on
Tim Eischens
    Champion:
  • 252 Answers
Your kettle has had a ground fault, and damaged the switch in the process. Do not Continue to Try and use.
Take the kettle to a gold medal dealer, and replace the switch in the cabinet.
Posted on Mar 05, 2015
5 Related Answers
Adavoid
  • 25 Answers
SOURCE: Trips circuit when you turn on the Kettle heat
When the fuse blows see what else in the house is out, maybe you have the circuit overloaded. Try putting the popcorn maker on a different unused curcuit to see if it still blows. Then you will know if it is the popcorn maker.
Posted on Dec 16, 2008
Anonymous
SOURCE: I have a Gold Medal Popcorn Machine 2086. The
I hate to put this as a solution because it really isn't. I have an old popper needing a new kettle and was told it was almost as much to purchase a new kettle than the whole machine. The kettle is almost the entire cost of the unit. I will be purchasing a new unit.
Posted on Jun 23, 2009
Oloyede Monsuru
  • 1468 Answers
SOURCE: The popcorn popper heats the oil and the warmer
hello,
the citation popcorn can be repaired the problem is from wiring disconnection
what you need to do to fix up the problem i to unscrew (open)the popcorn maker from the top with the bass tools then trace down the wire to the propeller (tuning device) to see if the disconnected wire then try to fix it back to it position but if there is no sign of disconnection then smell the wires if there is an born wire then the wire will need to be replace note this if any of these are not fine then you will have to replace the propeller i mean the turning device but
if you can not do this your self then you will have to take it to a technical shop around. you can get the turning device from an technical store / shop you
please take note of this, you must make sure that all source of power supply is put OFF from the machine.
than you.
Posted on Jun 12, 2010
atty4oc
SOURCE: Our popcorn machine is blowing the circuit when
Mine is doing the same thing. Did you get yours fixed yet? If so, what was the problem? Its got to be the wiring. If you take off the bottom square wiring cover access, you will see the two main wires and a grounder all connected. Sometimes the connectors melt with the heat. Maybe that is what is causing the short.
Posted on Oct 21, 2010
Anonymous
  • 11 Answers
SOURCE: need wiring digram for a citation popcorn popper
Here is a downloadable manual;
http://dallaspartytentandevent.com/manuals/16ozpopcorn_manual.pdf
Posted on Mar 27, 2012
Why is my gold medal popcorn model # 2552 machine not heating to pop popcorn anymore?
A kettle not heating is either a switch, kettle wires, thermostat, or kettle heater.
Check that the kettle is plugged in tight, notice if the switch lights up when switched, then contact your local gold medal dealer for repairs. It is always cheaper to repair a gold medal kettle than replace.
http://www.gmpopcorn.com/domestic-dealers.cfm
Heating element not working in old time Movietime popcorn maker
There are no replacement parts for Nostalgia Electrics equipment.
Double check that the kettle is plugged in, that the switch has power. If inclined open kettle and inspect wire connections and continuity, beyond that the popper is not fixable.
Wiring diagram kettle
The wiring good the kettle is pretty simple. Black goes to x on the plug white is y and ground is the green terminal. In the kettle the black goes to one of the two terminals on the thermostat. Then a jumper wire from the other thermostat terminal goes to one of the two terminals on the element. Then the white wire goes to the other element terminal. The ground or green attaches to the metal surface inside.
1helpful
After clening the kettle it blows breakers
You got the Heat element and or thermostat wet. Open the kettle to expose the electronics and let it dry for days. try again it might dry out.
Or you will need to replace the heat element, thermostat, and probably the wires. if it hasn't dried out by now.
Need to hook up wire for the element in the kettle of my GR6A1X -XX -X
Here is the wiring diagram for that model. Black(hot) wire to empty side of thermostat, red(indicator lamp) wire is doubled to the wire that goes to heat element, and the white wire is attached to far end of heat element.
Kettle does not heat up
Check the wires to the heating element inthe kettle.
2helpful
The kettle will not get hot! The light comes on and the #1 and #3 switch both light up, but no heat!?!?!
We disassembled the kettle and noticed that the black wire had been disconnected from the base connector which is attached to the heating element. We re-attached the wire clip to the harness and it heated up on the first try. Please note that you may need to crimp the wire connector to the base for a stronger hold. My guess is that as we were moving the unit back and forth the wire connector had seperated.
Star popcorn maker need insulation part between element/and pot?
there is insulation between the element and the outer kettle. This insulation can get brittle and crumble with age. I was lookiing for some parts as I have this kettle also and was told the kettle and parts are no longer available. If anyone has access to these parts please email me at [email protected]. Thank you. Gary
5helpful
2answers
NEED USER GUIDE DIRECTIONS FOR THE NOSTALGIA ELECTRONICS MODEL #kpm-508
Hi there!
This should be it -
Clicky here
Please rate as Fixya! if it hits the mark.. Thanks.
1helpful
2answers
Kettle Keeps jolting out of place
Popcorn popper is approximately three weeks old and now the popcorn clogs up in the hopper (cooker pot), the gear quits turning, and we have to pry the popcorn out. It worked perfectly when we first got it and now it is nothing but a pain to use. We tried several popcorns, cooking oils and amounts of oils, but the problem continues. I noticed the small spring located on the lower shaft doesn't cover the entire shaft. Is it supposed to be longer? Your prompt reply for a solution would be greatly appreciated or we will have to return the unit to our local retailer where we purchased it.
Top Gold Medal Kitchen Appliances - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
