Question about HP Photosmart 3310 Printer
I have a hp 3310, INK system ERROr & a Remember to turn off system at off button not wall error
I have tried everything, including taking off software & restarting. I spoke with HP for 4 HOURS NOTHING? We went on vacation cut power to house, come back & printer doesn't work?
Posted by KQHFARMS on
Anonymous
  • 14 Answers
If you mean Ink System Failure, it is usually caused by a mechanical gear failure inside. Refer to http://www.fixya.com/support/t439120-ink_system_failure_error_message
Posted on Oct 07, 2008
Chris Busch
    Master:
  • 474 Answers
Its probably dried up ink particles on the cartdridge and the contacts in the carrier.
First, if your going away for a while, its good to remove the ink and replace with new ones. They tend to settle and dry up if left sitting for too long. Thast why they are sealed when you bye them, to keep the contacts from getting buildup.
Try using a wetted paper towel and cleaning the contacts on the cartdridge and in the printer carier.
have printer unplugged when doing this.
Also, check the manual, theres often a key function that you can do tyo return the printer to factory defaults.
Posted on Feb 16, 2008
0xc18a0106 error from hp 3310 printer.... ink system has failed
That error code indicates a Ink system failure error message. Ink system failed mainly caused by your cartridge spitting extra inks into the copper contacts inside the printer. All you need is to remove all cartridge, clean the copper contacts at the back of it, clean also the contacts inside the printer (cartridge slots). Insert it back in after cleaning, unplug the power cord without turning off the printer, wait for 1 min before plugging it back in. Let me know the result.
Nov 23, 2010 | HP Photosmart 3310 Printer
Printing problem hp D7160 error 0xc18a0001 please help
Hi,problem can be solved .Please check out this link for the Ink System Failure problem.
fixyourownprinter.com/forums/printer/39471
These are from the link above:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turn it back on. You will have to turn the printer off twice and then it will recalibrate.
Our HP 3310 was having the same ink system failure. Tried everything I could find, and had just about given up when I found this forum. I didn't quite get the reset right the first time, but on the second try it worked. After holding down OK, Cancel, Black and Color buttons while turning it off, I turned it back on, it turned itself off and I turned it back on again, it started off doing the calibration and it took about 5 minutes, but when it was finished I had a working printer again.
Also
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
Hope this works for you. Please let me know.
Oct 28, 2010 | Office Equipment & Supplies
Ink system has failed error : 0xc18a0001 how do i fix this problem?
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx ink system error code displays on the front panel, service the printer.
Apr 01, 2010 | HP Photosmart 3310 Printer
Have a hp 3310 it says ink system failure error 0xc18a0106 it wont print,scan,copy and it does have enough ink. thank 4 ur help
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error then you may need to re-prime ink through the system to clear the error. There are good instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Feb 20, 2010 | HP Photosmart 3310 All-In-One InkJet...
Gives an error codeink system has failed error Oxc18aO1016
Remove all the ink cartridges. Wait two minutes. Plug the power cord into the back of the printer Press the On button to turn the printer on Install the ink cartridges when prompted If the error code does not display, the issue is resolved If error code is still there than printer needs to be repaired
Jul 08, 2009 | HP Photosmart 3310 Printer
Error codes
Hi
The error code 0x....... states IDS (Ink Delivery System) failure.Its an Hardware issue with the printer.
This problem could be resolved by resetting the printer.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON button for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait until the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait until the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off don't worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thanks
Riz
Dec 28, 2008 | HP Photosmart 3310 Printer
Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Nov 16, 2007 | HP Photosmart 3310 Printer
HP 3310 All In One Error
Try to reset the system by holding down the OK, Cancel, Black, and Color buttons at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turns itself back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartridges in the printer so that it can reset.
Oct 31, 2007 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
333 people viewed this question
Ekse
efs_perpends
efs_perpends
