Check out the videos
https://www.google.com/search?q=remove+leaf+trap+off+my+intex+sand+filter
SOURCE: can i hook up a intex pump to a sand filter
YES BUT PRICE OF SAND FILTER WILL PROBALLY COST MORE THAN THE POOL ITSELF
SOURCE: I have a 12x24 rectangular
I am not an expert on your particular Intex model ...
I believe your pressure readings are with in normal parameters. Is your water clean?
Is it balanced? Your goals should be Alkalinity of 100 (no less than 80 and no more than 120, pH should be 7.4 (but no less than 7.0 and no more than 7.8) and your chlorine should be 5 ppm. I recommend a DPD test kit Cyanuric Acid should be about 50 but no less than 40 and no more than 80. Cyanuric Acid is also called stabilizer. Its function is to protect the chlorine you are making in your cell. Refer to your owners manual for how much salt you should have in your pool. 3200 ppm salt is a window to shoot for. You can get a test kit for salt. Salt, like calcium, is persistent in the water. The only way salt and calcium get out of the pool is through back washing, splash out and what you carry off with your swimming attire. Chlorine is affected by the sun and materials introduced into the water by the swimmers as well as what jumps, falls or hops into the pool. pH is not necessarily affected by the sun but the other factors do come into play. A properly balanced pool (alkalinity-wise) will not have pH "bounce". If your pH is bouncing, that is an indicator that your alkalinity is out of whack.
If your pool is 4 feet deep, you have about 8,640. Your goal should be for a 8 hour turn over rate (your pump should be pumping no fewer than 1,120 gallons per hour). BTW, studies show that if you run your pump 24/7 with a 8 hour turn over rate, it still takes up to 5 days for every drop of water in your pool to actually pass through the sand.
You could install a flow meter in your return line. It is simple to do - drill a hole in the return line and attach the meter. Rule of thumb - a 1.5 hp motor (probably bigger than yours) will move about 50 to 70 gallons per minute through a 1/5 or 2.0 pipe. A 2 HP motor will move between 60 and 80 gallons per minute through a 2 inch pipe (and filter, of course). Get a flow meter at your full service pool supplier. It will come with full particulars.
With a clean filter (note the pressure) you should back wash when the pressure increases by about 10 PSIG (Pounts Per Square Inch on the Gage) from the pressure when clean.
I hope this information helps you ...
Thanks for your question @ FixYa.com
SOURCE: Leaky Leaf Filter On Intex Sand Filter
Hi thevideowatc
Check your o-ring seal to make sure it doesn't have sand under or on it, also it may have cracks in it, or the filter may have cracks in the housing...if that is so, then replace the housing.
Bud
