Question about FUJIFILM Cameras
SOURCE: s56oo fuju finepix camera focus error
Hit the lens (smack it on you're leg); that seems to be the solution..........
But try cleaning the lens and the AF assistent first!!
Posted on Dec 13, 2008
SOURCE: focus error
You will have to disassemble the unit. 2 screws on 1 side and 1 on the other and 2 on the bottom, pop the back off, being careful of the 2 ribbon cables attached to the rear and unock these cables and remove. 3 screws holding the top circuit board (remove the eye piece first and unplug the 2 cables attached to it) carefully unplug all cables attached to this top board and unscrew and remove (there is one on the bottom of the board that you must flip to unlatch. After you remove that board there is the power board... BE CAREFUL!!! The flash capacitor (the black tube looking unit on the bottom of this board) stores chrge and you WILL feel it if you touch the terminals... it they touch metal you will see fireworks so be careful. unplug the single red and black wire plug and unscrew the 3 screws here You do not have to remove the white plug with the 4 or 5 wires because you can just flip the board over out of the uni.. BE CAREFUL!!. unscrew the 2 silver screws securing the metal plate underneath and remove this plate. now remove the single screw left and pull out the lens assem. Here check 2 places... 1 is he zoom screw (it is behind the long silver panel) and also the focus screw (behind the shorter metal panel. Do one at a time. remove the screws from one of them and carefully lift off the motor plate. for he zoom line to metal ring on the screw into the groove of the lens (Shaped like a V) carefully screw the screws back in bu d ni tighten to tight, leave a LITTLE slack. (1/8 turn from tight). Now for the focus screw, remove the cover and align the ring to encase the top of the V The ring is shaped like < the lens is a > so just allow the rinng on the screw to "pinch" the top of the lens groove. secure like you did the other plate (dont forget to back out 1/8 of a turn) reassemble the opposite of disassembly and you are done... it look hard but it is actually pretty easy... any uestions email me at [email protected]
Posted on Feb 21, 2009
SOURCE: Internal battery of S5600 flat?
There is probably not much you can do but I guess you could try getting a newer battery.
Posted on Mar 31, 2009
Jun 30, 2010 | Fuji FinePix S5200 / S5600 Digital Camera
Dec 30, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Dec 12, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Oct 04, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Aug 26, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Jul 09, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Jul 02, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Mar 31, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Mar 10, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
35 people viewed this question
