Power on finish show to me this list(non-system disk or disk error replace and stroke any key when ready)
SOURCE: non- system disk or disk error
This means it cannot read the HDD in the machine. Have you left a disk in the CD/DVD slot or a usb drive in one of the usb ports?
You may have to insert your operating system disk in the CD/DVD drive and do a repair installation.
SOURCE: non-system disk or disk error
Your laptop isn't seeing your hard drive to boot up the system. You need to replace the hard drive.
SOURCE: System disk error or non disk error, replace disk
you have a disk in thecd or floppy which is not bootable, remove it and restart. and if no disk is in the drices you may have a bad drive.
SOURCE: non-system disk or disk error replace and strike
You need to correct this problem in the BIOS. Sounds like the BIOS is not enabling this device you are trying to use. Reboot computer, press enter, or F1,F2 repeatedly to get there.
SOURCE: I have a Compaq nc6220 and everytime I try to boot
This sometimes comes up if you have a disc in the cd drive or a USB drive attached.
If this is not the case, your OS is damaged and you can try a system restore / recovery, you may have these options if you can get the F8 menu to come up while booting.
If you have a windows disc you could try a repair installation, if not google "fix MBR"
