It is in auto reboot mode when a failure occurs. You need to take note of the SC Code that appears before it reboots. That will tell you what is malfunctioning. If it boots up with that - as in immediately - unplug the machine, remove the hard drive, plug in and reboot. Does it still occur? Yes? You need a service tech to check it out. No? Replace the HDD.
This is the general error code for all Canon copiers when there is a problem with the fuser getting hot. It can be reset once but most likely you'll have to have a qualified tech to fix it. Not knowing which model of copier I can't help you any further.
enter service mode by pressing 10871087
then press start button(green) four times.machine will restart and code will go.better check ur power supply for low voltage or fluctuation
H4 is nothing but an error code that appears due to power fluctation(in absence of a stabilizer).
You please enter # interrupt-C interrupt -14-start to clear to clear the error
is there an error code appear on panel display? if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Your error code indicates that the Fuser is not at the correct temperature, which can lead to smeary smudgy copies or scorched paper and a fire hazard, depending upon whether the fuser is too cold or too hot.
