Question about Motorola Radio Communications
What radios are compatable with motorola rdm2070d
What radios are compatible with Motorola rdm2070d
eradiostore
  • Motorola Master
  • 1,658 Answers
The Motorola CP110 MURS VHF is a nearly identical radio. Most 2 watt programmable VHF radios are programmable to the MURS frequencies.
Posted on Jul 25, 2014
1 Related Answer
Bajanguru
Sylvester Brathwaite
  • 7752 Answers
SOURCE: 8G micro SanDisk Compatible in a Motorola V3xx 3G
sir , i am sorry to tell you but that phone holds up to 1gb in memory nothing more.
Posted on Jun 02, 2008
How to program a Motorola rdm2070d to a baofeng bf888s
The RMD has a set frequency list. Those are factory programmed and cannot be changed. Your baofeng can be reprogrammed to most frequencies.
Critical! First, make certain both are in the same band: Uhf or Vhf.
Make the list of frequencies you need both radios to use. If the RDM has it in the list, you are good to go! If it does not, and you must match the Bao, get a new radio. There are no mods or hacks for an RDM.
Feb 25, 2017 | Motorola Radio Communications
What Motorola Radios are compatible to use with Motorola MV11C
NoCfghhjjfddf Gadsden cdsfgvhjb fdsffcc Cfghhjjfddf fccffcg
Jul 17, 2012 | Motorola MV11C VHF 2-way Radio
I just want to know how to clone the motorola rdm2070d
You will need the RLN6303 RDX Radio to Radio Cloning Cable, or two drop-in chargers, or the multi-unit charge tray. Instructions for cloning are on page 51 of the user guide: http://www.weatherconnection.com/manuals/RDV5100.pdf Best regards.
Jul 08, 2011 | Motorola Mag One BPR40 Two Way Radio
I have a motorola rdm2070d radio and am trying to turn the keypad tone back on
Keypad Beeps
Keypad Beeps can be enabled/disabled by
short pressing SB2 button (until radio 'chirps')
while turning ON the radio.
Here is a link to the user guide: http://www.astracomm.com/media/pdf/RDX_Display.pdf
Best regards.
Dec 27, 2010 | Radio Communications
I need to fix the frequency to match my other motorola XTN series radio model #XV2600 to my new motorola RDM2070d radio
Here is a link to the CP100 user manual, it is the sister radio2.gif to the XTN, and programs the same way. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Refer to the bottom of page 20 to get started programming2.gif.
Basically you hold in the PTT and the MON button while turning the radio on. Continue to hold them in until it stops making noise. This puts you in programming mode, and you can use the menu button and the + and - to walk you through reprogramming the radio.
We do not know specifically how your RDM2070d radio is programmed. You would need to know this to program your XTN to match. However, a good educated guess would be to start with Blue dot and Green dot frequencies off of the frequency chart in the user manual listed above. An educated guess on the code setting would be "zero" or "off".
Your radio dealer who supplied the RDM2070d radios to your corporation should be able to tell you the exact frequency and code; or read-out the radio.
Nov 03, 2009 | Motorola XTN Series Pro Two-Way Radio...
Program motorola rdm2070d need to program
The RDM2070D is non-programmable. It operated on pre-selected frequencies. (This radio belongs to a major corporation, and is not intended for use outside their company.)
Oct 12, 2009 | Radio Communications
Radio Communications Logo
382 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
