What shall I do is my touch screen does not respond to my touches?
SOURCE: Touch screen not responding at all
The touch pad is dead...it's a hardware issue...go to the vendor or workshop...within a year it is replaced for free.Good luck.
SOURCE: touch screen not responding.
try to reset your phone if dose not there will be hard ware problem
SOURCE: samsung s5233 touch screen not working
There is a simple answer to this and that is to replace the phones digitizer or touch screen and your problem solved.
br,
www.phonefreedomjamaica.net
SOURCE: dropped samsung jet touch screen not responding,
The touchscreen connector has come loose. It's a small flatcable which connects the digitizer (touch screen) with the pcb on the back of the screen. It's repairable, however you need to disassemble the complete phone. A great disassembly guide can be found here: http://www.formymobile.co.uk/jetdisassembly.php Good luck! :)
SOURCE: MY SAMSUNG GTS5233A'S TOUCH SCREEN IS NOT RESPONDING TO TOUCH.
The mobile screen would have been damaged or a device connected to your screen my be defected .Try to remove your touch screen safe guard sticker then clean the display. If this doesn't work out for you consult your dealer for replacement of new display.
Thank you !!
