Question about Fujitsu ASU12RLS2 Wall Mounted Indoor Unit Air Handler 12,000 BTU 1
Green light will not come on
I hit the 'powerful' botton and the fan kicked in and brought the tempurature of the room down. It ran for about 10 minutes and then shut off. The green light will not come on now.
2 Related Answers
John Bloomfield
  • 534 Answers
SOURCE: Fujitsu 42" Plasma Display shuts off after 20 minutes
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu '[email protected]'
Posted on Jun 05, 2009
John Bloomfield
  • 534 Answers
SOURCE: Have Fujitsu P42VHA 10/W. Works for a few minutes
Refer Fixya tips/tricks:
-http://www.fixya.com/support/r2810603-fujitsu_plasma_42_random_shutdown
Posted on Jun 02, 2010
InFocus LP130 - lamp doesn't turn on, front fan doesn't spin, LED doesn't turn on.
HOLD THE POWER SWITCH ON BOTTON OF THE UNIT
PLUG THE POWER CORD TO THE ELECTRICITY SOURCE
RELEASE THE POWER BOTTON AFTER 10 SECONDS
AND THEN TURN ON THE UNIT...
OR YOU MAY GO TO THE SITE (freepatentsonline.com) search the brand of the device....GOODLUCK.
Dec 06, 2011 | InFocus LP130 Projector
The dryer will not run its cycle, the drum does not turn nor does the fan run. However, the timer counts down as though it is running a load. Door is tightly closed and temperature in room is not below 32...
I have a g e dryer modle # dblr333eeocc when i hit the start botton the dryer just hums. If i spin the drum by hand and then hit the door switch the dryer will work untill you open the door
Feb 17, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Flashing green light on Mitsubishi WD- 62527 TV
how time dose the light blinking was your pix
dark if so you need a [email protected] for lamp. hope this help you out,
Aug 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Light come on for sec when hitting power and then no power to pc
Some PC desktop, when there is to much static in the motherboard it gives signs like this or when PC is on for a long period of time the processor is over heaten and needs to cool down a bit before you could switch it on. Try leave you PC for about an hour and try reboot. hope it helps
Feb 19, 2009 | HP Pavilion a705w PC Desktop
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
M6P09S2A-When compressor kicks in the lights in the room go dim
Call an electrician . Sounds like you are pulling too many amps. I wouldn't even run the fan....
Jun 09, 2008 | Maytag Portable Air Conditioner M6P09S2A
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Hampton Bay ceiling
When I've installed these fans in the past, the blue wire was for power to the light kit. If you don't have a light kit, just tuck it out of the way.
Aug 12, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Remote calibration
I installed three fans in the same room and one remote ran all three. In order to get the dimmers all to bring the lights up and down together, I changed the dip-switches in the fan housing so that the remote would only work one fan at a time. I then brought the dimmer lights all the way to bright. After all the lights were equally bright, I again altered the dip-switches so that all three and the remote were identical. The remote then dimmed all three lights equally.
Jun 16, 2007 | Hampton Bay AC438-VPW 52'' Vintage Pewter...
Fujitsu ASU12RLS2 Wall Mounted Indoor Unit Air Handler 12,000 BTU 1 Logo
26 people viewed this question
Top Fujitsu Heating & Cooling Experts
Marvin
Marvin
jdthefixer
Muntejaya Ginting
Muntejaya Ginting
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
