U770 sw will turn on but not take photos
SOURCE: OLYMPUS U770 SW TOUGH CAMERA / Olympus U770 SW -Camera 2007
You should be able to order what you want from most any photo products supply store. You can also get in contact with Olympus directly, and enquire for a local dealer for what you need. '
Jerry G.
SOURCE: Olympus Stylus 1030 SW
Try soaking in a bowl of clean warm water. I had the same problem and this resolved it. gotta love water proof camera!!!
SOURCE: olympus 770 sw lens cover not closing
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
SOURCE: Olympus u770 sw 7.1 No
Hi
Sorry to hear about your issue with the Olympus mju 770 SW. There's a couple of things you can check and try, before thinking about a repair or binning the camera and getting a new model.
1. Check the contacts on the battery are clean?
2. Clean the contacts inside the cameras battery compartment are clean?
3. Is the charger actually charging the battery? Try another battery or see if you can test the existing battery with a multi-meter to check there is some power in it.
It is fairly common for chargers to fail, so it's worth checking out but don't go spending money on a new charger unless you know it will fix your problem.
Hope this helps
David
