Why does my cub pop/backfire and die when I give it any throttle? it will start and idle fine, but as soon as you try to throttle-up it pops, backfires, and dies? Mower has kohler 12hp.
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
SOURCE: Kohler courge sv720-0010 on cub cadet
SOUNDS LIKE IT HAS SOME BAD GAS YOU MAY NEED TO CLEAN THE CARB AND IT MAY NEED A KIT
SOURCE: I have a cub cadet 1500 series with 200 hours! I
I think runnng out gas. Your fuel cap vent and unhook fuel line from carb. and see if fuel run out. And check if fuel filter in the right direction.
SOURCE: my cub cadet runs fine untilm the pto is engaged then it backfires and dies?
check the safety switch on the seat
SOURCE: I have a kohler 18 hp twin engine on a cub cadet.
Check to make sure idol isnt set too high, make sure the air filter is infact clean to prevent it from chocking itself, make sure choke is off :-) and also make sure you idol all the way down when you kill it. Make sure your spark plug is good to prevent flood, and detonation, peaceout.
