Question about AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA
What does error code 07 mean on an aeg upright freezer?
Alarm is going off and red light flashing.
1 Related Answer
buddymcl777
Bruce McLeod
  • 67 Answers
SOURCE: Upright freezer not cooling adequately
Go to there website and see if you can find your model. You can also contact them from there.
http://www.aeg-electrolux.co.uk/node145.asp?CategoryID=2595
Also get yourself a stand alone fridge and freezer thermometer - leave it in for an hour -that will establish what the temperature really is which will help in diagnosing the cause.
Also trying unplugging it for 15 minutes so the display board loses power - then plug it back in - sometimes that will reset it.
Posted on May 04, 2009
Having restarted my upright Freezer how long will it take for the flashing red light to stop flashing
what was the reason for the trouble code --if problem not fixed trouble light will keep flashing if light flashing due to temp when setting is reached will stop
Jul 17, 2016 | AEG 10.35 cu. ft. / 293 liter Upright...
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Red alarm light flashing
Good Morning Friend, thank you for allowing me to assist you!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your freezer by unplugging it or flipping the household circuit breaker. It is good to wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause. - Z
Jul 18, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
CE flashing in the temp window of upright freezer I can silence the alarm by pushing the reset button but the red light blinks. Inside the freezer the indicator means operational error
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 08, 2010 | Frigidaire 16.7 cu. ft. Upright Freezer...
Freezer alarm and signal light comes on daily
The beeping and light indicates the need for a new battery (9v)
May 22, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Aug 10, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Alarm
the alarm is there to warn you that the freezers not up to set tempature.. The reason as I see what you wrote would be a stuck or burnt out auto defrost timer motor. or the units got a leak in the refrigerant line??? good luck
May 18, 2006 | AEG 3.32 cu. ft. / 94 liter Upright...
AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA Logo
Top AEG Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an AEG Freezer Expert? Answer questions, earn points and help others
