I left it plugged in all night but it still won't heat nor will the light come on I put in fresh water, but it just poured out cold what could be wrong?
If it's plugged into a GFCI outlet, press the RESET button. Do not press the "test" button.
If still no joy, plug something else into that outlet and see if it works. If it doesn't, check that the breaker on your main panel for that circuit isn't tripped. If it is, push it all the way to the off position, then back to the on position. You should hear it click like a light switch.
SOURCE: Bunn coffee maker not working
My warm indicator light is not working. Only used less than a month.
SOURCE: My Bunn coffee maker is leaking water
SOURCE: Bunn VPS Series Commercial coffee maker won't brew
Hello. I would like to suggest that you pour in water, with a container under the funnel, until water does come out, it sounds like the water has just evaporated too far, and it requires more than a pot to bring it to the top. In the future, if you do not use it for a day or more, you need to unplug it, or just pour a pot of water in to keep it at level, as this unit heats all the time it is plugged in, and can actually evaporate all the water away, blow the element, damage the thermostat, or worse permanently damage the unit.
here you can find the user manual:
http://bunnomatic.com/pages/techdocs/manuals/pourbrew_warm.html
Hope that helps, and thank you.
SOURCE: My bunn stopped working completely.
Plug something else into the same outlet and see if you are getting electricity in that outlet. If it is on a ground fault circuit, push the little red button in in the middle of the outlet. or check the breaker box to see if the breaker has kicked. It is unusual for everything to quit working at the same time if it is getting power.
<?php
if(!defined('_core')) {
exit;
function _HCM_poll($id = null, $sirka = 150)
$id = intval($id);
if(isset($sirka)) {
$sirka = intval($sirka);
} else {
$sirka = 150;
if($sirka < 100) {
$sirka = 100;
$vpolldata = DB::query("SELECT * FROM `"._mysql_prefix."-polls` WHERE id=".$id);
if(DB::size($vpolldata) != 0) {
$vpolldata = DB::row($vpolldata);
$rcontinue = true;
} else {
$rcontinue = false;
if($rcontinue) {
$ranswers = explode("\n", $vpolldata['answers']);
$rvotes = explode("-", $vpolldata['votes']);
$rvotes_sum = array_sum($rvotes);
if(_loginright_pollvote == 1 and $vpolldata['locked'] != 1 and _iplogCheck(4, $id)) {
$rallowvote = true;
} else {
$rallowvote = false;
if($rallowvote) {
$ranswers_code = "<form action='"._indexroot."remote/hcm/pvote.php?_return=".urlencode(_indexOutput_url."#hcm_poll_".$GLOBALS['__hcm_uid'])."' method='post'>\n<input type='hidden' name='pid' value='".$vpolldata['id']."' />";
} else {
$ranswers_code = "";
$ranswer_id = 0;
foreach($ranswers as $item) {
if($rvotes_sum != 0 and $rvotes[$ranswer_id] != 0) {
$rpercent = $rvotes[$ranswer_id] / $rvotes_sum;
$rbarwidth = round($rpercent * ($sirka - _template_votebarwidthreduction));
} else {
$rpercent = 0;
$rbarwidth = 1;
if($rallowvote) {
$item = "<label><input type='radio' name='option' value='".$ranswer_id."' /> ".$item." [".$rvotes[$ranswer_id]."/".round($rpercent * 100)."%]</label>";
} else {
$item .= " [".$rvotes[$ranswer_id]."/".round($rpercent * 100)."%]";
$ranswers_code .= "<div class='poll-answer'>".$item."<div style='width:".$rbarwidth."px;'></div></div>\n";
$ranswer_id++;
$ranswers_code .= "<div class='poll-answer'>";
if($rallowvote) {
$ranswers_code .= "<input type='submit' value='".$GLOBALS['_lang']['hcm.poll.vote']."' class='votebutton' />";
$ranswers_code .= $GLOBALS['_lang']['hcm.poll.votes'].": ".$rvotes_sum."</div>";
if($rallowvote) {
$ranswers_code .= "</form>\n";
return "
<div class='anchor'><a name='hcm_poll_".$GLOBALS['__hcm_uid']."'></a></div>
<div class='poll' style='width:".$sirka."px;'>
<div class='poll-content'>
<div class='poll-question'>
".$vpolldata['question']."
".(($vpolldata['locked'] == 1) ? "<div>(".$GLOBALS['_lang']['hcm.poll.locked'].")</div>" : '')."
</div>
".$ranswers_code."
</div>
</div>\n
