Question about Maytag Bravos MTW6600T Top Load Washer
Noisy spin cycle and stuck on high
Used to be really quiet. now it is very loud and it spins fast no matter what level it's on.
Charles Houlroyd
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
I have a Maytag Bravos Washer - I have the same problem. It cost as much to change the spin bearing as to buy another washer.
Remember its whats inside that maters - I will never ever again buy another Maytag!
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Posted on Mar 22, 2015
Richard Warren
    Genius:
  • Maytag Master
  • 2,548 Answers
Spin solenoid could have water leaking onto it and it stuck on , but noise is most likely caused by bearing getting water into them,dose it leek water on the floor?
Posted on Jul 19, 2014
5 Related Answers
Tony Coultrip
  • 183 Answers
SOURCE: Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Posted on Jul 30, 2007
duby1990
Justin Duby
  • 370 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Posted on Nov 18, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Posted on Dec 06, 2008
jonniewalker
Starnley Johnwells
  • 1031 Answers
SOURCE: Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Posted on Aug 20, 2009
GodBlessU
Aparajita Batabyal
  • 3513 Answers
SOURCE: My washer runs fine until the spin cycle then it
The noise was indeed coming from the water pump. To clean the pump on this top-loader you have to unplug it, pop the top open, and remove the front face of the cabinet to expose the motor and pump. Slip off the two metal clips hugging the pump to the motor. Place a towel under the motor before detaching the hoses - there's a plastic drip pan between the pump and motor to guide the water away from the motor. Unclamp the two hoses from the pump by squeezing their spring-clamps with pliers and sliding them further down the hose. Pull the hoses off by lifting the pump off its axle and pulling it out while wiggling the hoses loose. I found a small sock jammed in the pump - it must have fallen to the outside of the basket but inside the drum during the last spin cycle, and went down the drain hose. Check the pump for damage and replace if necessary. For future troubleshooting, remember that a clogged pump causes squealing, diminished spin speed, and slow drainage.
Posted on Sep 12, 2009
Why do i have loud noises coming from my washing machine only whilst it spins
The bearing in the drum has failed and it's always noiier as it spins faster as there is more debris being thrown around inside the hardened steel casing of the bearing. Bad news is that's a write off. Uneconomical repair. It will tear its self apart shortly, probably leaking grease into the wash and leaving black marks everywhere, oor the drive belt will come off, or the drum will impact the front gasket and fill the drum with smoke. Any way you look at it, it's almost certainly going to destroy a load of washing. Throw it away now before it wrecks your washing
Aug 21, 2016 | Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Spin vibrations
Make sure the legs on all four corners are down tight and even level the machine with this 4 pads. If the machine is level it will vibrate less, and then not all machines are completely quiet when working, especially on spin cycle..
Jan 22, 2014 | Kenmore Washing Machines
Kitchenaid quiet care washing machine
not enough information. there may be a loose or broken drum spring, or the belt may be loose and or worn. If its a two speed one of the gears may be worn.
Dec 31, 2011 | KitchenAid Washing Machines
Spin cycle is very loud, used to be very quiet.
It could be Quite a few things either not level to the ground or off track on the inside. try running washer without clothes see if it still makes that sound.
Jun 25, 2009 | 2006 Maybach 62
Very noisy during spin cycle
You probably need new shocks for the washer as they break over time. They cost $37 each and you can replace them your self. If you don't fix these you may end up breaking the motor controller and while the part may be covered under the warranty the diagnostic and labor is not.
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
My wash spins SO loudly
hiya
sounds like your drum bearings are in need of replacing.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 19, 2008 | Washing Machines
Loud noise during spin cycle
I bought the frigidaire affinity washer. It was quiet until it began the spin cycle, then it sounded like a jet taking off and began to bounce. Come to find out we set it up improperly. You must remove all shipping bolts on the back of the machine and make sure it is level. Ta Da!! it now runs perfectly quiet with little vibration.
May 05, 2008 | Frigidaire GLTF1670A Front Load Washer
Spins really fast and loud and is leaking at bottom of tub where shaft goes in
buy a new washer .specifically a direct drive whirlpool,no belt. maytag washers are not what they use to be.
Jan 04, 2008 | Maytag Legacy Series Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
263 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
Michael Thomas
Michael Thomas
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
