Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
I have samsung french door refrigerator 2 door 2 drawer with vibrating a noise. I have removed the back panel and the noise does not seem to be cominng from this area. any suggestions.
vpitman1
    Scholar:
    New Friend:
  • 59 Answers
We have a different model Samsung, and I've heard a vibrating or buzzing noise twice. First, if the water filter isn't an exact fit (even Samsung's filters rattle), it will rattle. Second, if either of the ice makers gets stuck or jammed, it can make a vibrating noise. If our freezer drawer isn't making a good seal, ice will build up under the drawer or in the slides. Ours makes more of a humming noise, when this happens. Other areas to check: something stuck in the runner of your drawers or shelves (if yours pull out). There are also vents that draw air in and out of the cooling unit, and things in front of them may vibrate or rattle, too.
Posted on Jul 19, 2014
5 Related Answers
Anonymous
SOURCE: Samsung french door fridge not working?
I had the same problem ("OF" on display and not working) and just found a fix and it worked (on SAMSUNG site).It was correctly stated that fridge is in "demo" mode. You need to push and hold POWER FREEZE and ENERGY SAVER buttons (not "Fridge button and the Power Cool buttons" as it was suggested above).
Posted on Jun 28, 2008
Anonymous
  • 22 Answers
SOURCE: refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Posted on Nov 13, 2008
dennis dodge
  • 1891 Answers
SOURCE: Samsung French Door Refrigerator not cooling
it's only 4 weeks old ./ don't mess with it it has a warranty you may void it if you work on it . it is probably in the main digital control in th fresh food .. but i would call the seller and they can set up a service for it .. mm
Posted on Dec 24, 2009
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: RF263 series Samsung Refrigerator just began
Hi
The sound comes when there is ice build up around the fan and the fan will hit it causing this sound. You can try to leave it unplugged for around 4-24hrs and also make sure that the area near the back is clear so that airflow can get through. If the issue returns then replace the thermostat. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 01, 2011
raj somaiya
  • 5370 Answers
SOURCE: Water is pooling under vegetable/deli
Its a defrost problem.Click this link below and follow the troubleshooting:--- http://technoanswers.blogspot.com/2011/07/water-is-pooling-under-vegetabledeli.html ---------- This should help.Thanks.Helpmech.
Posted on Jul 08, 2011
There is a vibration noise on my Samsung #RF217ABBP. The vibration is loudest on back midway up. Anyone know what causes this vibration and is there a fix?
Try cleaning the condenser coil underneath the refrigerator. A dirty coil can make the compressor run extremely hard and vibrate. If this coil is clean, a compressor mount maybe loose or broken.
Feb 06, 2015 | Samsung RF217ABBP Bottom Freezer French...
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
Removing samsung freezer drawers
There are 3 bolts that hold the bottom of the freezer door in place, if you remove them the door will fall to the floor then youmcan pull it off then you can access the drawer
Sep 07, 2012 | Samsung RFG237AARS Bottom Freezer French...
My Amana French door bottom refrigerator is making a buzzing noise. The noise is intermittent and seems to be getting worse. The ice maker seems to be work ok. Any suggestions on how I might fix it?
I USED TO HAVE THE SAME PROBLEM. CHECK TO MAKE SURE THE WATER LINE BEHIND THE UNIT IS NOT VIBRATING AGAINST IT, CAUSING THE NOISE. ALSO CHECK THE BOLTS ON THE BACK OF THE UNIT TO MAKE SURE THEY ARE TIGHT. THE HOSE WAS MY PROBLEM AND WHEN I FINALLY FIGURED IT OUT, I WAS SO RELIEVED NOT TO HEAR THAT BUZZING NOISE ANYMORE. AND I THOUGHT IT WAS ACTUALLY INSIDE THE FRIDGE!
Jul 14, 2011 | Amana AFD2535DES French Door Refrigerator
2 questions
Remove the drawers and locate the small round vent hole on the lower back wall. Place a piece of sturdy tape over the haole and re assemble unit...problem solved.
Dec 21, 2009 | LG LRFC25750 Refrigerator French Door
Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Apr 17, 2009 | LG LFX25960ST Stainless Steel French Door...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
512 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Gerry Harvey
Gerry Harvey
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
