Question about Electrolux Washing Machines
Electrolux aqualux 800
Belt size for this model
Bassa Skinn
    New Friend:
  • 15 Answers
Written on old belt, usually 1975
Posted on Jul 19, 2014
3 Related Answers
mnwarfield10
mark warfield
  • 452 Answers
SOURCE: electrolux aqualux 1200 water leaking from door
have door gasket changed .....01179512835
Posted on Dec 30, 2009
John Wilkinson
  • 174 Answers
SOURCE: washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
Posted on Jul 20, 2010
chrispolkele
Electrolux
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: EW/200i, Electrolux Aqualux 1200I, what size belt fits it, is it Lenght 1195?
    Can you provide the exact model number for this unit?
    Posted on Sep 20, 2012
    Hi I have an Electrolux EW Aqualux 1200 in a rented property no manual for the programs would you be able to email me one if available Many thanks rachel
    rachel you will find it here if its model number is ew1200
    http://www.manualslib.com/download/46075/Electrolux-Ew-1200-I.html
    Jun 21, 2016 | Electrolux Washing Machines
    My wash/dry cycle has finished but I can't open the door. Is there a manual release please?
    turn the dial and listen for a click to release the door. no their is no manual release
    Jan 06, 2015 | Electrolux Washing Machines
    Free User guide for an Aqualux 1200
    I don't know if this helps or not, but Manualsonline.com lists thist one for an Electrolux AW1202 if it is the same machine http://www.serviceforce.co.uk/pdfs/U33052.pdf.
    If that isn't it, get the model number off the machine specification plate (usually inside the lid, or on the back) The cutesy name on the front is seldom the actual model number the technicians use to order parts...don't know why they do that. With that specification model number, you might be able to look it up here and get the downloadable manual http://laundry.manualsonline.com/np/usermanuals/mfg/electrolux/washing_machine_product_list
    Hope that helps
    Jan 21, 2011 | Washing Machines
    Washer/dryernot drying-Electrolux - Aqualux 1200 EW
    Jul 20, 2010 | Electrolux Washing Machines
    Electrolux aqualux 1200 water leaking from door
    Dec 30, 2009 | Washing Machines
    Installing an Aqualux (Desiree) whirlpool bathtub
    call the manufacturer Asteria Bath Company at1-800-288-4002 and they can send it to your email address.
    Nov 02, 2008 | Home
    Beater Bar Belt Removal from Upright Electrolux Vacuum
    http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
    Generic problem for all Vacuums
    Beater bar Belt Removal from Upright Electrolux...
    Posted by wrenn on Jul 14, 2008
    I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
    I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
    http://electrolux.com/ Customer Service 1-800-896-9756
    Electrolux Home Care Products – North America
    P.O. Box 3900 Peoria, IL 61612
    Thanks, Don the Vac Man
    Go Ahead. Use Us.
    Jul 14, 2008 | Vacuums
    Washing Machines Logo
    Top Electrolux Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
