I was gifted a three drawer metal file cabinet, standard filing size. It is locked and without key. I don't need the lock to work. I was advised to drill the key hole to disassemble the lock. Any advise? The name of the cabinet co: McDowell Craig Norwalk. Norwalk, California. The lock itself says, "Chicago Lock Co."
SOURCE: Monitor's "Control Lock/Unlocked" menu appears by itself
I have a PDF of the service manual, and I'll be glad to email to you upon request. It may help. [email protected]
SOURCE: cental locking on MK 3 GOLF
check wires and plastic vacumme lines in between all the doors.pull rubber boot back look for broken cracked wires and vac lines.same thing on hatch open hatch at the left hinge for the hatch and roof you will see the rubber boot.pull it back look for damaged wires vaclines
SOURCE: file lock?????
hello sir here a list of software try these http://www.filebuzz.com/findsoftware/Nokia_7210_File_Lock_Software_IN_JAR_FILE/1.html
SOURCE: Drilling out lock on scooter luggage box
if you have a new lock & key assembly,you can drive a small chisel or stout flat blade screwdriver into the old key hole about as far as a key would go. with a wrench on the chosel,turn it like you would the key to open it.now look inside,there is a clip or a nut holding the cylinder in place.R&R.
SOURCE: Key fob lock / unlock and int cen/locking button does not work
The key may have lost it programing. This link tells you how to reprogram the key. Good luck.
