Most Kia cars have fuse boxes that are well labelled. One is located in the engine bay. The other is in the passenger compartment, under the dashboard, either driver's side or passenger side. Check the fuel pump relay if you have confirmed that your fuel pump is not receiving +12V at the connector end. Some models have the relay as part of the main relay. Some have individual relays. These relays are located nearest to the ECU behind center console, screwed to the posts at the sides of the console.
It is located under the hood in the fuse box, it should be a relay.
SOURCE: 2002 kia optima 2.4
www.kiatechinfo.com Sign up for login and you can locate any and all information there.
Electrical issue to you name it.
SOURCE: 2002 kia optima /windshied wipers do not operate
The relay (fuse type thing located under the hood) was good as well. If that is the case then the motor is the issue. or the switch itself.
SOURCE: 2002 Kia Spectra has no power to fuel pump
try to locate the fuel pump relay. the pump should be turned on by the relay controlled by the computer. If you can't find the relay, to your local parts store, sometimes they have a component locator and can tell you exactly where it is.
SOURCE: Location of a 2002 kia optima fuel filter
Hi on this car the fuel filter is in the fuel pump so the pump as a whole will be replaced. To get to it you will have to remove the rear seat bottom cushion. There are 2 12m bolts inbetween the top cushion and the bottom. remove them and then on the front of the bottom cushion there will be 2 plastic clips pull up on them and the cushion will pop up and you will see the acc panel for the pump.
SOURCE: fuel filter on a kia optima
it is accessed beneath the trunk floormat, up near the base of the back seat.
