Lahiru Thilakarathne Posted on Jul 19, 2014
Whenever i turn on the printer i get a error 6C10
I tried replacing the ink and also ran the service mode. Still the error keeps popping up. What should i do. Printer: Cannon MP560
Nickhamm23
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 31 Answers
  • Posted on Jul 19, 2014
Nickhamm23
Contributor
Level 1:
New Friend:
Cheetah:
Answers
31
Questions
0
Helped
5638
Points
71
This error is related to the ink absorber/waste ink tank located internally in the printer. Normally you would have to send your Canon to be serviced to resolve this problem, but there is a video turotial on YouTube that shows how to reset this error: Canon MP550 Ink Absorber Reset (6C10 Error Code) - YouTube
2 Related Answers
Anonymous
  • 687 Answers
  • Posted on Mar 24, 2010
SOURCE: i just changed an ink cartridge on my mp560 canon
If you have used the printer over 6,500 copies then the ink pads below the cartridges will be full and need replacing all printers will stop and give a warning to this effect it can be reset using a secret menu if you have an LCD control panel use my Brother DCP-340CW solution
http://www.fixya.com/support/r4065602-dcp_340cw_machine_error_46_photo_capture
Anonymous
  • 4 Answers
  • Posted on Apr 14, 2010
SOURCE: MP560 Canon Printer Error 6C10
The above suggestion worked short term, but in about a couple of hours, I'd get the same old error code again. Finally, I found a solution that worked for my MX860 on fixya.com written by "pineworks". The link is as follows: http://www.fixya.com/support/t4097826-aborber_full_error_message
Don't know if you've found an answer to this problem yet, but I had the same issue for about three months. Finally, I found a solution that worked for my MX860 on fixya.com written by "pineworks". The link is as follows: http://www.fixya.com/support/t4097826-aborber_full_error_message
For months, I've had to power off, disconnect from computer, and power on again to kick-start the printing. It was driving me crazy. So far, "pineworks" solution has been a permanent one. Been about a week and have had no problems yet.
1helpful
Printer Canon PM 990 does not print, but shows error code 6C10. What can I do?
Whenever your OKI Printer shows the OKI c5300 toner sensor error on the display screen, follow out the blog carefully. It contains all the needed information to help you rectify the error. You can also connect with OKI Printer Repair Services to get completely satisfactory results.
  • Whenever this error code appears, this most prime thing that you need to do is to check whether all the blue toner levers are firmly pushed towards the back or not.
  • As you are done with it, check the sensor. Ensure whether it needs to be cleaned or not. You can find the sensor at the back of the plastic cover on the side of the drum.
  • Use a small and lint-free cloth to clean the plastic cover and the silver arm.
  • The sensor will be a very fine powder and should also be easy to remove.
  • Make sure that the sensor lever on TS1 is pushed up or not.
  • Clean the arm properly. Also, check whether the sensor lever is pushed up as it needs to be or not.
  • It is not set properly; the machine will not pick up the sensor on the drum. Push the disc up to make this Oki Canon Printer Error Code 990
MG8120 6C10 error
The error code indicates an issue with the purge unit.
This usually requires a repair\service of the unit.
first of all please turn off the unit....unplug the power cable
now remove the cartridge...manually slide the carriage assembly\ printhead back and forth
also clean the rail against which the assembly slides with a tissue ensuring that there is no ink residue on it
clean the golden contacts of the cartridges and the printhead with a cotton swab dipped in little alcohol
once these steps have been done follow the below steps as well
manually move the printhead to far left
on the far right there is a little white plastic tab that is spring loaded
just check that if its not getting jammed
push the tab towards the front of the printer
once done just turn on and check the status
in case still the issue persists and you get the same error code, then it is an issue with the purge unit.. if the unit is within warranty cover please contact Canon and get the unit serviced...if not, you need to contact a repair tech for physical replacement of the part..however, my personal suggestion is that a repair will not be cost effective
http://www.smoothprinterservice.com
PIXMA MP640 6C10 fout
You need to replace the ink absorber and reset the error code by following the reset procedure:
Resetting error 6c10
It wont print
Double check that the error isn't 6C10. I also thought I had an 8C10 error also and that's how I found your unanswered question! But I couldn't find any other internet reference to 8C10 but I did find a YouTube fix for a 6C10 error message. So I got my reading glasses and looked again. Sure enough it was a 6C10 error! I followed the instructions for the 6C10 error fix (resetting Ink Absorber Reset) and my printer is now functioning. Bonus note: My printer is a MP620 and the reset was for a MP550. Same error number though! and also same solution. By now your printer has probably crossed that printer rainbow bridge... but hopefully someone else will need your help? With my reset, I am going to run my $$$ ink cartridges out instead of maintenancing the absorber and then toss mine as well!
Canon MP-5200 printer will not turn on display
6C10 means you need to replace the ink absorber. After this it require to reset the error. Reset 6C10
My printer is only 5weeks old / installed end of March and i have this error message on the display screen 6C10 I have tried ti turn the printer off and back on again but the error still occurres. Do...
This error is caused when the ink absorber has got full and needs to be replaced.
This is something you can get done by a local service centre or a Canon service centre.
Andy
18helpful
2answers
I have installed Continuous Ink System on my canon ip2770 printer but it still reports my color cartridge has ran out of ink. How can I reset the ink level of the cartridge on my printer?
Press resume button for 5 secs. This works for other canon models using cis.
Thank you for using fixya, have a nice day!
If this helps, please rate me :)
15helpful
2answers
Canon MP540 Error 6C10
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
16helpful
3answers
Canon PIXMA IP3600 Service error 6C10, and doesnn't print at all
I bought a new Canon PIXMA MX860. I plugged in the printer and turned it on as directed. I continue to get an error: 6C10 There is no mention of the error code 6C10 in any of the manuals or on the...
Top Cannon Office Equipment & Supplies Experts
NOEL
NOEL
Grand Canyon Tech
Grand Canyon Tech
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
