SOURCE: Dell C400 Laptop Battery not charging
Go into the battery properties and check if the battery is charging. If it says it is, then test it, use the battery to see if it really is charging, they will sometimes give a false reading. If it's not charging, then check the power supply with an ohm meter for the proper output. If this all checks good, but the battery isn't charging, then I'm afraid you have a failed power management system on the motherboard. The power management system controls the charging along with other power related aspects of the machine. If the power management system has failed, then unfortunately, you will have to replace the motherboard in order to fix it.
