HP Deskjet 3510 e-All-in-One Printer Logo
A
Anonymous Posted on Jul 18, 2014
How do fix "black cartridge problem" appears on my HP 3510 after cartridge refilled and installed
After refill and install in printer, "black cartridge problem" appears. what do i do now
Van Allen
Level 2:
Sergeant:
  • Expert 282 Answers
  • Posted on Jul 19, 2014
Van Allen
Expert
Level 2:
Sergeant:
Answers
282
Questions
Helped
83565
Points
717
Buy a new cartridge.
5 Related Answers
Anonymous
  • Posted on Dec 05, 2008
SOURCE: hp f4288 all in one black cartridge( N0.818) refilling method
hp cartridge 818 black refilling method
Ajkill
Anand Kumar
  • 2035 Answers
  • Posted on Feb 17, 2009
SOURCE: refilled cartridge not printing
Try to cartridge manually ,please follow the instructions :
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Anonymous
  • 259 Answers
  • Posted on Jul 14, 2009
SOURCE: My printer HP OfficeJet J4580 not printing I have
HP 4500 Chip Rs.1050 /- only change the chip and after printer is working fine
E-Mail:[email protected]
Anonymous
  • 1751 Answers
  • Posted on Apr 26, 2010
SOURCE: hp94c Installed refilled black ink but printer does not recognize
try cleaning the contacts with a wet towel
from both cartridge (black and color) and in the printer
where the cartridges get in (metal pins)
Anonymous
  • 241 Answers
  • Posted on May 28, 2010
SOURCE: Just installed refilled black ink cartridge on hp
By using refilled cartridges you will always have this problem. Each cartridge has a chip that lets the printer know when it is full or empty. By pressing the ok button you may be able to clear this message. However, most of the time you can still be able to print and ignore the message.
2answers
Hello,after refilling ink cartridges HP21 and
Since HP’s ink technology is different from other manufacturers, they do not recommend to use refilled or remanufactured ink cartridges. Though the cost of genuine HP cartridges are bit expensive than the other cartridges, HP cartridges are manufactured in keeping mind the important factors print quality and customer satisfaction. Using the refilled cartridges may degrade the print quality and may damage the printer’s internal hardware.
I request you to use genuine HP Inkjet cartridges and verify the result.
:) Dr Tony
Installed updates now HP printer won't accept refilled ink
HP does not recommend refilling thier tanks, their print heads are built in to the cartridge so if you refilled it before resetting the tanks you will have to go to www.hp.com and run the trouble shooting tool for free to fix your issue. you may have to replace the catridge.
Black and color cartridges refilled. originals back in printer...printer says no color cartridge installed.. have cleaned contacts on cartridge and machine, NO difference. can we print just in black if...
You need to have both black and color cartridges installed with functioning electronics to use your printer. Sounds like your original color cartridge and the refilled color cartridge you purchased both have bad electronics. I recommend Cartridge World or Office Depot for cartridge refills because they electrically screen their cartridges before selling them. You need to buy either a new or refilled color cartridge for your printer to work.
3helpful
2answers
Installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Printer displayed that Black Cartridge needs to be changed. Changed out cartridge, but printer does not find cartridge. I get a message that say, "Install Black/Photo cartridge." I tried re-installing the...
Reset according to manual. One of those HP jokes that might help.
You replaced with an original or 3rd part refill?
These cartridges can't be reset after refill so the error message may indicate something else.
HP LaserJet P2015 cartridge refill
The simplest way to get around this check is to have atleast 2 cartridges. The printer checks the chip to check if the same cartridge is installed again. By refilling a different older cartridge and installing it you can fool the printer and get around this check.
Cannot get the printer to accept the new HP black cartridge
Make sur u r not using refilled carts...
Cleaning the copper contacts on the carts as well as the copper contacts inside the cartridge carrier..
And install the carts thru the HP software..this might fix..or the carts are defective
k24674
Grand Canyon Tech
Grand Canyon Tech
