SOURCE: Panasonic DMC FZ30 shutter speed adjustment
set to s -then adjust using command wheel by thumb- 8 secs to 1/2000
SOURCE: shutter speed
The shutter speed on my pentax optio e10 is so slow. I hate the camera and wouldn't recommend t.
SOURCE: Shutter speed
What you are referring to is not the shutter speed, but it is how fast the system takes to lock in the focus and determine the exposure/quality/white balance of the scene, and in some cases if a flash is required, getting enough power into the buffer to fire the flash with enough light for the scene. It needs to do all of these steps before it takes the photo.
More expensive cameras have bigger internal processors and memory and can do these steps faster.
My suggestion is to anticipate a scene a bit more before shooting. Especially if its a moving subject. You can pre focus and get the camera to evaulate the scene before taking the photo by pressing the button half way. Then when the action starts, just click it down the rest of the way.
SOURCE: Shutter speed very slow and has trouble focusing
There is a diaphragm between the shutter button and the shutter switch that causes the camera to focus before the shutter is pressed all the way down. It is likely that the diaphragm is punctured and needs to be replaced. There is also a small possibility that the hidden secondary battery inside the camera is going bad.
SOURCE: Nikon D60 Digital SLR--Slow Shutter Speed
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
