Question about Amana PTH093B35AJ 9100 BTU ThruWallWindow Air Conditioner
Where is the "Manual Heater Reset Switch" on an Amana PTH093B35AJ? Unit has good A/C but no heat at all. All components test good.
Unit has great A/C but no heat. Heater element replaced but no change. Unit has stickers on it stating it has a "Manual Heater Reset Button" but I cannot find it. Where is it? Control board has one flash every five seconds which indicates no problem with control board. Help.
Posted by Joe Choroba on
Marc Brewer
    Problem Solver:
  • 9 Answers
Sounds like a bad reversing valve
Posted on Aug 24, 2014
2 Related Answers
Jack Spooner
  • 1015 Answers
SOURCE: Heater stopped working. Fan works, control panel
The front panel should be held in place by four screw at the corners or snap in place. Either remove screws or pull gently on top right corner to remove cover. You should see a red reset buttom type reset. Push it in to reset. Hope this helps. Thanks.
Posted on Nov 13, 2010
harjeet singh
  • 86 Answers
SOURCE: Amana PTC153A50AD Electric Heater
1. copressure not working.
2 check spare parts of a/c.
3 wiring
Posted on Mar 17, 2008
Spa not heating but heating gauge says 36C. How can I troubleshoot before calling the company?
check for a reset button on the heater side
check that the heater element is not failed
Feb 21, 2016 | Pool & Spa
What else can I try, my Intertherm water heater is not heating water off the lower element?
I should like to hope I have your answer.
If yours is like most U.S. model, it is called a 220 volt unit.
That is not really 220 volts, it is really 2 separate 110 volt units.
What that means is, there are actually 2 separate 110 volt hot wires to the water heater, usually one hot wire is black, and the other hot wire is red.
One is for the upper heating unit, one is for the lower heating unit. Perhaps your lower unit has blown the circuit breaker for that line.
I mean the circuit breaker in the main fuse box/circuit breaker box.
Did you test the lower wiring to see if the hot wire is hot?
If it is hot, be sure to test the ground wire, and also the wiring between the bottom and the top of the heater inside it.
God bless your efforts.
Jan 04, 2018 | Water Water Heaters
Electric dryer won't heat
Thermal overload cutout tripped or is defective and needs replaced. Look for a red reset button near the heater element on the thermal overload. If no reset button, replace the thermal overload cutout. The timer itself could be defective, which will prevent power going to the heater element.
Sep 14, 2015 | Roper Dryers
I have removed front cover on amana model ptc153b35am unit says it has got a manaul reset for heater cannot locate it can you help
The manual reset is a small switch on the computer control board. If that doesn't fix the problem, while you are there, you will see 2 small black boxes wired into the computer board marked "heater 1" and "heater 2". These are relays, one of which has probably gone bad. You can either order a computer board for about $100 or replace the relays yourself with a soldering gun. You can order the relays for $4.02 apiece from Digi-key Corp. Part # is JTN1aS-PA-F-DC5V for the relay.
Dec 10, 2014 | Amana Heating & Cooling
Where is the Manual Heater Reset Switch on an Amana A/C and Heater Unit Model number PTH093B35AJ? The unit has several stickers that state it has a "Manual Heater Reset Switch".
Almost certainly it is a bad relay on the circuit board. Sometimes you can slap the side of the unit by the control box to temporarily unstick the relay, after which the heat will come on for a cycle or two. There are two relays on the circuit board marked "heater 1" and "heater 2". You can order a new circuit board for about $100 or replace the relays at $4 apiece (order online from Digi-Key, requires solder connections). Part number JTN1a-PA-F-DC5V.
Jul 18, 2014 | Amana PTH093B35AJ 9100 BTU ThruWallWindow...
Amana #PTC153b50AJ ser 0410686783 Customer heard a pop in unit and it went off. Breaker was tripped. Reset breaker and unit runs in a/c mode but does not heat in heat mode. This is not a heat pump but...
I'm seeing a master switch on the control board, try a reset there. But, sounds like a bad element. You need to test continuity through your heater components. When testing a component unhook wires first, as they will still have continuity even if bad with wires attached.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 04, 2017 | Amana PTC153B50AJ Electric Heat Air...
I have an Amana PTAC unit model no. PTH153B50AM. It will not heat, but the fan runs continuously in the heat mode. The unit has a label that says it has a manual reset for the heater, but no direction as...
First unplug the unit......Take the front cover off, take the wire screen off where the front fan is there is 4 or 5 screws that hold the plate that was under the screen. The electric heating elements are under that plate between the evaporator coil and the front blower wheel. It will lift straight up and give you access to the elements. In the electric heating element area there is a limit switch with a red or black button in the center of it push it to reset the limit it is on the right hand side by the controls. I wish I could find a picture to show you but I couldn't find one. It is not easy to get to... Hope this helps.
Feb 12, 2011 | Amana PTH153B50AM Air Conditioner
I have a Reliance 501 electric water heater. There are two panels. In the top panel is a red "reset" button. On two occasions this button has popped and turned off the unit. I have pushed the...
ECO reset button trips when thermostat senses high heat event over 150 degrees F, or when upper or lower thermostat is defective. There are other causes: if tank access covers and insulation are missing, and when element is shorted to ground in center of element so that element continues heating through one leg of 240V circuit after thermostat turns off.
Ordinary tank-type electric water heater is fully repairable by homeowner using generic parts from hardware store or home center.
1) Replace upper and lower thermostat for about $28, and if problem persists, then do troubleshoot shown in step 2 below.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
2) Take 30 minutes and troubleshoot before replacing any parts.
Troubleshoot requires cheap multimeter from home center.
Install battery in multimeter.
When testing voltage, rotate multimeter dial to 240 or 250 or 277 VAC.
When testing continuity or elements, rotate multimeter dial to ohms (upside down horseshoe symbol is ohms)
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Jan 13, 2011 | RELIANCE ELECTRIC WATER HEATER
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
I have a AMANA PTh153B50AE (PTAC unit). The air conditioner works fine. It is when I turn on my heater and it does not get warm. It just blows cold air. I have looked at the board and it appears that...
I have the same problem, and I found the manual reset inside the unit. Turn the power off, and unplug the unit. Remove the outer cover of the unit ( inside cover ) , and remove the 2 screws holding the " wire mesh " in the front of the cover. Pull the wire mesh up and out of the way, then carefully pull out the heating element.
On the heating element, where the wires are connected, there is a manual reset button... Push the button in, till it resets...
My reset was on the upper left connection of the wires... just looks like a small push button, but the reset is recessed a bit.
Replace all covers and plug back in.. working fine..
Nov 12, 2010 | Amana PTH153B50AE Air Conditioner
Amana PTH093B35AJ 9100 BTU ThruWallWindow Air Conditioner Logo
366 people viewed this question
Top Amana Heating & Cooling Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Dennis Boxerman
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
