Question about Radio Communications
How do I know if my jabra bluetooth is charged or charging or needs charging?
Posted by shari on
5 Related Answers
Anonymous
SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
Posted on Jul 10, 2007
Anonymous
  • 7 Answers
SOURCE: Won't charge up...
I had the same issue. So what I did was get a small screwdriver, opened the A210 case removed the battery. You will notice orange tape (remove it) then attached to the battery is a small board (the defective part) . Cut away the board, then you will need to solder the wires back to the thin metal film leads. And voila it will now charge, make sure to never let it charge for more than 2 hours. Do this at your own risk. Of course this will void the warranty.
Posted on Feb 04, 2008
Anonymous
SOURCE: CHARGING My Jabra bt160
i have the same problem
Posted on Feb 18, 2008
Anonymous
  • 9 Answers
SOURCE: Jabra BT135
Firs turn it off then..........
then hold the button for 10 seconds
it will now pair with your phone
the code is "0000"
Posted on Apr 22, 2009
ktkc5ffq
SOURCE: Jabra JX10 Bluetooth doesn't/won't charge
Not sure if this is a solution or if it occurred by chance. Like many on here, I put my Jabra JX10 away for a few months while not using it. The time come for me to need it once again and found that it was dead. Made an attempt to charge the unit with negative results. The unit would only show a green "charged" LED indicator as if the unit was fully charged. I tried plugging the unit into the charger multiple times, and took the cradle out of the loop and just used the AC cord alone. Still with the same results. I pulled the outside cover off (slowly), to be sure not to break the small fragile tabs that hold it in place. The battery takes up majority of the space. Removed the battery but DID NOT disconnect from unit. Plugged the charge cord into the unit and immediately got a red LED charging indicator. While charging, placed the battery back inside and put the outside cover back on. The unit continued to charge for a little over an hour before the green LED "charged" indicator came on. I used the unit throughout the day to test it with no problems. Not sure what removing the battery from unit did, especially when it was not disconnected, but it worked. I hope to see similar results.
Posted on Jun 09, 2009
My headset will not turn on
Hello
Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
Dec 30, 2010 | Jabra BT150 Wireless Headset
I charged the BT350 using the Jabra Charging
I called Jabra Support and they are sending out another unit. The technician indicated that the battery is likely defective and is not field replaceable.
Thank you,
Dec 11, 2009 | Jabra BT350 Bluetooth Headset Headset
Adding my bluetooth to my phone
it needs to see the jabra..could be a timing issue...start phone (charged) start headset (charged) phone should announce it has found a device *would you like to connect?* message.....another thing..in tools you need to tell phone to look for bluetooth devices (on)
Oct 22, 2008 | LG RUMOR Cellular Phone
May 26, 2007 | Jabra BT250 Consumer Headset
Radio Communications Logo
888 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
