Question about Soyo Computers & Internet
Brightness needs to be increased
I need to increase the brightness
  • 2,509 Answers
The usual method is to press the menu button and follow the on screen prompts, have you done that?
Posted on Jul 18, 2014
Anonymous
SOURCE:
Anonymous
SOURCE: how to increase the dull CRT monitor brightness
WHAT YOU HAVE TO DO IS TO AMMEND THE CONTROL SIDE OF THE VIDEO GRAPHICS ADAPTER
Posted on Jan 06, 2007
bammbammfran
Fran Bednar
  • 159 Answers
SOURCE: need to increase voltage on powersuply
Hi John.
No idea why your post is under monitor problems ???
I figured you need an adapter mod for a monitor !! SO don't kill my ratings since this is not my area of expertise, but I can try to give you some input anyway, not so much a solution !!.
I would NOT recommend altering a 12 volt adapter for charging a battery especially if it is a standard ac adapter.. You may get it to give you 13.8, but your amps may be wrong.
Battery charger depends on type of battery also. Don't know if you are using NIMH or Nicad or acid based ?
The differnt style batteries use different type chargers. Wrong charger will burn up a battery or blow it up !!
If the battery is a 13.8 then normaly the charger would be putting out 2+- volts more than the battery rating. If you battery is 12 then a 13.8-14 would do the trick. (12 volt car batteries for instance take a 14+ volt source to charge them)
I would recommend looking here
http://www.powerstream.com
They have all those goodies and may give you an idea. for what I think you are doing.
Fran
Posted on Oct 18, 2008
Anonymous
  • 51 Answers
SOURCE: Volume to low, need to increase , please help.
install sigmatel audio driver and it will increase ur vol
Posted on May 20, 2009
paul7of9
paul7of9
  • 1189 Answers
SOURCE: how to increase brightness of my monitor i put it
Hi, you can try this; in a clear area of the Desktop screen (right)) click, once the desktop window open, click on Personalize, next click on Display Settings. You can adjust the brightness by by doing the following: On the resolution scale adjust from Low>High; you can do this until you are satisfied with the view. In the (Colors) drop box, click the down (Arrow), and choose the "Highest" color (16bits>32bits) etc. Next click to open the (Advance)) settings, click on the (List All Modes) button, once the window open choose the (Highest) settings: example (1366 by 768, True Color (32bit), 60 Hertz. Remember to click the "Apply", and "OK" buttons after each selection or change. "Hope this helps' Ya"
Posted on Jan 29, 2010
profpat
  • 109 Answers
SOURCE: hp mx 705 monitor the brightness menu appears andautomatically increases brightness to 100
i do monitor repairs, on some other models, i change the 7805 5volts regulator that feeds the microprocessor chips, and the problem of osd displaying is fixed, but on this particular HP mx705 crt monitors, it has no 7805 regulator, but a transistor that is regulated by a zener diode.. will try to replace it and its corresponding filter capacitors..if the problems is fixed..i will post the results..
Posted on May 09, 2010
Adjust screen brightness
go to start-->control panel--->display--->adjust brightness
i need to know what operating system you use this will work for only Vista and 7 and 8 and 8.1
Oct 10, 2014 | IBM ThinkPad T40 2373 Notebook
How to increase brightness without fn+f6 keys because for now the f6 key is not working
Press and hold the "Fn," or function, key on your EEE PC-1000's keyboard.
Press "F3" while holding "Fn" to lower the brightness on your monitor.
The brightness on your computer decreases each time "F3" is pressed.
Press "F4" while holding "Fn" to increase the brightness on your monitor.
Each time "F4" is pressed, the brightness increases.
Press "F8" while holding "Fn" to decrease the volume from your EEE PC's speakers.
Each time "F8" is pressed, the volume decreases.
Press "F9" while holding "Fn" to increase the volume from your EEE PC's speakers.
Each time "F9" is pressed, the volume increases.
Press the "Ins" key while holding "Fn" to take a screen shot, or make a copy of what is currently on the computer screen.
hope this helps
Oct 08, 2012 | ASUS EeePC1000 1000H 1000HA 1000HC 1000HD...
My brightness menu will not go away
Does the brightness keep increasing / decreasing or only the menu remains on ? If it keeps increasing / decreasing, that particular switch must be defective. Need to replace the switch. Samir
Mar 21, 2011 | Samsung SyncMaster 215TW 21" LCD Monitor
Want to know how to lighten up the screen. need an instruction manual
These are the Function keys
<Fn> + <↑> Volume up Increases the sound volume.
<Fn> + <↓> Volume down Decreases the sound volume.
<Fn> + <→> Brightness up Increases the screen brightness.
<Fn> + <←> Brightness down Decreases the screen brightness.
Nov 09, 2010 | Acer Aspire 5100 Notebook
To increase or decrease the brightness of monitor
Try Fn+ F5 for decreasing the brightness and Fn+F6 to increase the brightness.
Look for the icon of a sun on the F (F1-F12) keys.
If you need further assistance please post.
Mar 10, 2010 | Sony Computers & Internet
Can i adjust the brightness of the screen?
Laptops are provided with a combination key that can increase and decrease brightness. Find on your keyboard 2 keys with a bulb and an arrow key. Mostly you'll have something like a sun. Hold down your FN key (near your left ctrl key) and press one of those keys depending on whether you want to increase or decrease brightness. In Dell the keys will the arrows keys themselves
Jun 26, 2009 | Dell Latitude D630 Notebook
Need best settings for a Panasonic TH-50PZ85U
As with any display best settings are up to the user.
Some general rules about adjustment of a video display device apply
1. if the display is too bright you would decrease brightness by turning it down
2. if the display is too dark you would increase brightness by turning it up
If a display is too bright it will shorten it's life span so you want to keep the brightness down
Contrast must also be adjusted in the same manor
You should increase color saturation to suit your self
Increasing the color saturation too much will decrease the life of the display and look ugly
so you want to add just enough color to satisfy your taste.
Loch Hiam :-)
Sep 14, 2008 | Panasonic Televison & Video
Computers & Internet Logo
32 people viewed this question
Top Soyo Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
