Question about Bulova Accutron Watches
I648725 Need to know what year it was made
Posted by Al coste on
Terrence MacArthur
    New Friend:
    Problem Solver:
  • 9 Answers
Since the 1950s Bulova has used a 2 digit date code, usually on the back below the serial number. The letter is the decade (L= '50s, M='60s, N=70s, etc.) and the number is the year. For example, a Bulova with a date code of M3 was made in 1963, one with N0 was made in 1970, and so on. Prior to the 1950s, it's more complicated.
Posted on Aug 06, 2014
  • Terrence MacArthur Aug 06, 2014
    My answer revised: The first Accutron was made in 1960. Since the 1950s Bulova has used a 2 digit date code, usually on the back below the serial number. The letter is the decade (L= '50s, M='60s, N='70s, etc.) and the number is the year. For example, a Bulova with a date code of M3 was made in 1963, one with N0 was made in 1970, and so on. The Accutron is collectible (and valuable) because of its tuning fork movement, which was a revolutionary horological innovation. It was incredibly accurate and precise (two somewhat different things), guaranteed to be within +/- 2 seconds a day. Unortunately, Seiko introduced the quartz movement in 1969, which was even morev accurate and precise (although an improvement beyond +/- 2 seconds/day isn't really of any practical use in a wristwatch). It was also a lot simpler and cheaper to make. The last "true" Accutrons were made in 1977, the same year they made the first quartz "Accutrons", which are not collectible. Bulova currently makes automatic (self-winding) mechanical movement Accutrons, which are a very nice upper mid-level watch, and an Accutron II, which mimics the original in its looks and its sweep second hand, but which uses their "Precisionist" movement, which is a quartz movement.
    PS: With Bulovas, at least since the 1950s, the serial number cannot be used to determine the manufacture date.
Need owners manual for Pulsar PQ2001 Digital Watch
I don't know whether the offer is still good after two years, but take a look at this thread.If you just need to know how to set the time, look here.
Apr 10, 2012 | Watches
My CK 2247107 watch is one year old now, Suddenly the watch stopped running, Surely cannot be the battery. Do i need to change any mode. I tried setting different modes on the pushbutton to reset the...
mcdevito75 here, One year old, most likely the factory Battery and at 1 year old the battery is old, who knows how long the battery was in the watch before you bought it 1 year ago?? The battery is the first suspect. Look for a small watch repair shop in your area for a new battery first.
Feb 09, 2011 | Watches
How do you know witch setting to make on the leap year adjustment on the Citizen Calibre 8700 model. +1, +2, +3...?
On Leap Years, the function dial is to be set to '0'.
Add one for each year after...
So, for 2011, set the function dial to '3' since it has been 3 years since 2008, the last leap year. Next year it should move/be set to '0' again since 2012 is a leap year.
Dec 23, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
I have a Sharper Image Swivel Worldtime Clock model # M1600/M1601 I have lost the instruction manual. I need helpin changing the temp. fromCentigrade to Farenheit and I need to change callender mo.and...
To change the calendar, push the mode button until the calendar section starts flashing. Then press the up or down button to move the calendar month and year first. Once you get to the right month and year, press set, then the date should start flashing. Again, use the up or down button to get to the correct date, then push set. That should get it done.
Regarding the temperature, I used to know how to do that but am now basically clueless. My batteries went out, and when I changed them the temp started up as Celsius and I cannot get it fixed.
Nov 23, 2010 | Watches
Need an expert on the new minute repeater by campanola, sold one at the retail jewelry store i work at, gentleman wants step-by-step hands on instruction as to the minute repeater function as well as the...
in order to set the repeater chime you need to set the watch and the sub watch to the same time.
This watch has comes with crown in position 0 , if you pull it out one level it becomes position 1 and if you pull it out one more time it is position 2 .
There are 3 buttons on the watch also. The button directly above the crown is button A the button below the crown is button B and the button directly across the crown is button C.
To set time you must first pull out crown to position 2 when the small second hand is at 12 o'clock position and it is stopped.
The mode will also at this time go to 0 and the sub watch second hand( the long second hand with the sun on it ) will also go to 0.
At this time you can just move the crown to set the proper time to the main watch . Now if you press the B button to set the sub watch . Each time you press the B button it will advance one minute hold down the B button and will advance time faster.
Do this to set the sub watch time make sure you watch the am and pm to make sure you are getting the proper time of day.
if the sub watch second hand ( the long second hand) is not aligned to 12 oclock then press the A button keep pressing button or hold it down to go faster until it is aligned at the 12 oclock position
Now push crown in back to 0 position for your time for your watch and sub watch should be set.
Set leap year.
Pull crown to position 1
Press the B button to adjust leap year.
the leap year is set by how many years from the previous leap year it has been . So 2008 was the previous leap year so we will h ave to set leap year at year 2 . The hands of the leap year are connected to the month so you must hold down a and b button or just press the b button to get to year 2 .
once you do that your leap year should be set.
to set the Repeater ( this is a beep from the watch to tell you the time with sound) make sure crown is in 0 position and hold a button for a couple of seconds to activate Reapter.
you can press any other button to end the chime .
also to get to leap year view while crown is in 0 position hold down the b button for 2 seconds . Pushes any button to return to normal calendar.
Oct 16, 2010 | Citizen Campanola Perpetual Calendar...
My watch is running slow and I have replaced the battery
Not knowing the model or make I would say it will need to be sent to watchmaker for an overhaul/clean/ oil/ adjust. I dont know how old your watch is,either. Most watches have 1-2 year movement warranty.
Jul 19, 2010 | Timex 27191 Wristwatch
I havent worn this watch for about a year the battery has 10 year warranty and was working fine.now it has stopped working.
A few watch companies...Bulova being one of them used to give a 10 year warranty but I dont know of any batteries that actually last 10 years! The average life of a 1.5 volt silver oxide battery is 2-3 years (sometimes a smidge longer) depending on the age and condition of the watch. A 3 volt lithium battery will get on average 3-4 years.
Im guessing that your battery is probably dead! :-)
Jan 18, 2010 | Bulova Marine Star 96C30 watch
My citizen skyhawk watch which is under one year old has stopped working, there is nothing on the lcd screens.
This watch is a "echo-drive" I presume. Do you wear the watch every day? If not , is it put away in the dark? If it is , this watch needs sunlight for it to stay charged. Try putting it on a window sill for 24 hours and see what happens. If this dosn't help, then you need the capacitor changed. You said you have had this watch for about a year, Citizen has a 5 year warrenty, so if it still dosn't work get ahold of them and they should be able to help you. If you don't want to wait to have it fixed you can go to any REPUTABLE watch repair shop (NOT a jeweler) and they shoul be able to help you. The price will probibly be between 45-65 dollars. If you need more help PLEASE let me know, and I will be glad to assist you further.
Sep 15, 2008 | Citizen Watches
Battery
a 395 cell is what is normally put in this watch from the manufacturer I wouldnt advise using a lithium battery
Nov 17, 2007 | Luminox Field 821 wristwatch
Setting the perpetual callender 8700
The year is now 2008 a leap year. You should set the watch to leap year.
Nov 02, 2007 | Citizen 8700 BL8000-54L Wrist Watch
Watches Logo
81 people viewed this question
Top Bulova Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Lisa Christine
Are you a Bulova Watch Expert? Answer questions, earn points and help others
