Chromo Inc Chromo AAAAAAAA White 4gb 7" Android 4.0 Touch Capacitive Screen 1.2ghz 512 RAM Mid Tablet Pc Wifi 3g Camera Tr-a13 - Bonus USB 2.0 to Micro USB Adapter Logo
Fred James (Tripp) Posted on Jul 18, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to get my cromo inc tablet to power on after i factory reset it
Steve Reynolds
Level 2:
Scholar:
New Friend:
  • Expert 93 Answers
  • Posted on Jul 18, 2014
Steve Reynolds
Expert
Level 2:
Scholar:
New Friend:
Answers
93
Questions
0
Helped
13399
Points
121
Odd, but try this: Some tablets do not fully shut down, even though the screen goes blank. Hold down the power button for 30 seconds, wait 15 seconds, and then try again to power up (hold power button for 3-5 seconds). Wait patiently for the power up, as power after factory reset may take longer than a 'typical' start-up. Good luck!
1helpful
How to factory rest nid-1070 naxa core tablet
To factory reset the Naxa Core Tablet NID-1070, follow these steps:
  1. Power off the tablet by pressing and holding the Power button until the tablet turns off.
  2. Press and hold the Volume Up button and the Power button at the same time until the Naxa logo appears.
  3. Release the buttons and wait for the Android system recovery menu to appear.
  4. Use the Volume buttons to navigate to the "Wipe data/factory reset" option, and then press the Power button to select it.
  5. Use the Volume buttons to highlight "Yes" and then press the Power button to confirm.
  6. Wait for the tablet to complete the factory reset process.
  7. Once the process is complete, the "Reboot system now" option will be highlighted. Press the Power button to select it and reboot the tablet.
After the reboot, the tablet will be reset to its factory settings.
How do you reset a digital 2 tablet without volume buttons
If your Digital 2 tablet doesn't have volume buttons, you can still perform a factory reset using the following steps:
  1. Power off your tablet: Hold down the power button until your tablet shuts off completely.
  2. Hold down the power and home button: Once your tablet is powered off, hold down the power button and the home button simultaneously. The home button is the physical button located on the front of your tablet, usually below the screen.
  3. Wait for the recovery screen to appear: Keep holding down the power and home button until the recovery screen appears. This may take a few seconds.
  4. Navigate the recovery menu: Once you see the recovery menu, use the touch screen to navigate the options. Select "Wipe data/factory reset" using the volume buttons on the screen.
  5. Confirm the reset: Use the touch screen to select "Yes - erase all user data" and confirm that you want to perform the factory reset.
  6. Wait for the reset to complete: Once you confirm the reset, your tablet will erase all user data and reset to its original settings. This may take several minutes to complete.
  7. Restart your tablet: Once the reset is complete, your tablet will automatically restart. You'll need to go through the initial setup process again, like you did when you first got the tablet.
Please note that a factory reset will erase all of your data, including apps, contacts, and media. Be sure to back up any important data before performing a factory reset.
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
Stuck on email and password screen. i have tried every known email and password combo. how do i reset it?
Do a factory reset . If you don't know how to do it go to you tube and enter in the search box how do I do a factory reset , or how do I reset email & password combo .
1helpful
I have forgotten my password and i want to factory reset the tablet. How do i do this?
Have you looked on the side of the tablet for a tiny hole to reset using something small like a paper clip? If not, try turning off, the holding power switch and volume switch at the same time. remember to remove any SD cards first. It should bring up amenue to reset if its android.
The light doesn't work and I read nightly. Can it be fixed?
Try a factory reset: To factory reset the glo: hold the power button ON for 15-20 seconds to make sure it is off. Press and HOLD the light button while turning on the Glo. That should put you into a factory reset if that will solve the problem (no guarantees but it has worked for others in the past).
Get rid of a password of of a tablet and you forget the password
Factory reset! Turn off, Press power and volume together, select factory reset!
Bypass a forgotten lock code
Make sure the tablet has been turned off first by holding down the power button until you get the power off dialog box and choose power off. Then hold down the volume button and while continuing to hold the volume button, hold down the power button until you get a message like 'booting into recovery mode' or a dialog box that allows you to go into recovery mode and do a factory reset. Some tablets may boot into a screen with the Android robot on it that you can touch the robot and get to the recovery mode screen. When you do a factory reset, all user information stored on the tablet will be cleared, including the passwords or lock codes.
2answers
How do i reset my android dragon touch tablet
Try holding power and both volumes if it reboots normally try again but let go of power when the Android pops up
Top Chromo Inc Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Chromo Inc Tablet and eReader Expert? Answer questions, earn points and help others
