Question about Lenovo IdeaPad Yoga 13
How do fix a blank screen for my Lenovo ideapad Yoga 13 ?
suresh km
    Problem Solver:
  • 7 Answers
Have graphic card inbuilt your ideapad ?
Posted on Jul 18, 2014
5 Related Answers
KingDWS
Dave King
  • 1606 Answers
SOURCE: Lenovo S series ideapad will find my dlink router no network addr
Generally if you can see the D-Link then everything is trying to talk. Would have to know if the d-link is new out of the box or is part of an existing setup. If the d-link has been part of the network I would suggest that you don't have the security settings correct. If you right click on the network icon and look at the send received numbers. If received is zero then your problem is you don't have the security key (WEP or other type)) setup. If you are getting recieved numbers you may not have the DHCP setup in the d-link. DHCP assigns the numbers to the computer but the d-link has to have this turned on in some models others it is by default.
If both your laptop and dlink are not new and specifically about a year old then I would also suspect that the dlink has died or is dieing on you. If you have had periods of disconnects or slow jerky network acess then these are signs of the dlink having problems. The wireless part tends to go after a year or so while the wired portion probably still works. When they go they are annoying as they work then they won't and so on.
That is you next step to try is to plug in your laptop direct to the wired connection on the dlink to test if the problem is the wifi portion of the dlink. If it connects your problem is the wifi and you probably will have to replace the unit. Next plug it into the cable modem and see if the problem was in the dlink itself.
Posted on Jul 09, 2009
Anonymous
  • 38 Answers
SOURCE: Lenovo IdeaPad Y530 - 40512SU screen is dark
Have you installed the Lenovo EnergyCut drivers? Without it, laptop may not work properly and turns extra hot. Try letting it cool down before you try again.
Posted on Oct 28, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: How to fix sounds on Lenovo IdeaPad Y530
Some model ThinkPads have different network, video and audio drivers and unless you know exactly which one is installed in your ThinkPad, you need to download all the drivers and install each driver until you find the right driver.
When you download the drivers, write down the device driver and it’s file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive.
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer, Use this link: -
http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
You can download the various drivers and then you click on and run the various driver files, they will then unzip and expand into a sub folder on C:\drivers Then install the various drivers from this folder (run the set-up file).
Posted on Jan 22, 2010
Anonymous
  • 561 Answers
SOURCE: Lenovo Ideapad Y450 mouse isn't working...
Hi
Unfortunaltey you have liquid in the mouse pad area, unfortunatley there is no quick fix.
The laptop will need to be booked into a reputable PC shop for repair
Regards
Shauqat
Posted on Jun 10, 2010
Michael Green
  • 3799 Answers
SOURCE: My Lenovo Ideapad Y560 have
Try connecting an external monitor to the VGA port on the left hand side towards the rear. Then turn it on. If you have a picture then you will need to look for the key that swaps the video output on the laptop. in the event that this doesn't work it sounds as though the Graphics module in you unit is broken. This will means taking the unit to a repair facility. I hope the problem is the easy one. Best of luck!
Posted on Mar 22, 2011
My tab stucked during start and its freeze in lenovo logo
Android Tablet stuck on boot screen ! Bypass it in easy steps ...
? 4:36
https://www.youtube.com/watch?v=HErn0-GcQqE
Jan 4, 2014 - Uploaded by My Tablet Guru
If your Android tablet is stuck on startup or boot screen, then bypass it ... 1) Press the volume up or volume down or home button when the tablet start, .... is support on my tab . its also stoc on android logo plz bro help me . .... How to fix most tablets if they freeze - Duration: 2:21. by JunkyBlake 236,241 views.
Lenovo Yoga 8 Tablet stuck on boot screen - Lenovo Community
forums.lenovo.com > ... > Lenovo Tablets > Android Yoga Series Tablets
Apr 21, 2014 - I have the exact same problem with a yoga 10, it is stuck on the lenovo... Yoga 8 was working fine last night but today it's stuck on boot up with ... lenovo tablet a3300 gv stuck on lenovo logo
May 17, 2015
Stuck in Lenovo Screen - G500
Apr 6, 2014
Lenovo IdeaPad A1000 stuck on recovery mod
Dec 23, 2013
ThinkPad hangs on boot - stuck at Thinkpad screen
Feb 2, 2012
More results from forums.lenovo.com
Dec 21, 2015 | Lenovo Computers & Internet
SPSS to lenovo ideapad
What error message comes up in particular? Can you post a picture or copy the error message?
Mar 14, 2015 | Lenovo IdeaPad Yoga 13
Computer will not boot
Hi.
I would say your OS is broken. Can you acess your bios menu?
Mar 06, 2015 | Lenovo IdeaPad Yoga 13
Do you have inverters for ideapad yoga 13
They are advertised on the UK version of Ebay, under "Lenovo Ideapad Yoga 13 Screen Inverter (ref 19765) "
Lenovo Ideapad Yoga 13 Screen Inverter ref 19765
Sep 29, 2014 | Computers & Internet
Shaking screen Lenovo ideapad yoga 11s
The video may be failing. Backup any important data. Then, try to make sure you have the latest drivers. See this... https://www.youtube.com/watch?v=-i1wWtdEmcY
and this... https://www.youtube.com/watch?v=pdVFKFLRQXg
Just search on Youtube for "Lenovo ideapad shaky screen"
Jul 26, 2014 | Lenovo IdeaPad Yoga 11S
Where is the battery located in my Lenovo ideapad Yoga 13?
it is located inside the machine and you have to remove the backcover for the same
Jul 18, 2014 | Lenovo IdeaPad Yoga 13
My Lenovo yoga's screen has gone blank. I have had it less than two weeks. What can I do?
I would contact Lenovo technical support if I were you. They can fix or replace your system under warranty if need be.
Jul 09, 2014 | Lenovo Yoga IdeaPad Ultrabook 13.3"...
Lenovo IdeaPad Yoga 13 Logo
211 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
