Question about EdgeStar CWR530SZ - 53 Bottle Built-In Wine Cooler
I have a cwr530sz wine cooler. The fans run but it does not get cool. Temp set to 65. The highest it will go but will not bring temp down below room temp at about 76. What are the likely issues. It looks from the wiring diagram like it has a single cooling element
Posted by Paul Williams on
Louis F Hoholek Jr
  • 1,140 Answers
Defective compressor. Refrigerant leak. Defective thermostat. If the compressor is running, then it has a refrigerant leak.
Posted on Jul 18, 2014
  • shelly G
    shelly G Jul 30, 2014
    I believe my relay is bad. Does anyone have a manual that shows the way to replace that part?
  • Louis F Hoholek Jr Oct 26, 2015
    Manufacturer manuals only show you how to operate or give information about the equipment, not how to repair it. You possibly could do an online search to try and find a video on how to do it.
Paul
    New Friend:
I have this same problem. if it's one of those problems you mentioned , are they easy fixes? defective compressor, refrigerator leak, defective thermostat?
Posted on Oct 24, 2015
    No. You need a brazing torch, brazing rods, nitrogen pressure tank, vacuum pump, refrigerant and compound refrigeration gauges to do the job.
  • Paul
    Paul Nov 02, 2015
    so basically cheaper to just buy a new one. thanks.
Manage my life com sears
It depends on if there is anything in it! Those types of coolers are only designed to drop temps of wine bottles to below room temp a few degrees. They don't cool like refrigerator in your kitchen.
Jul 22, 2014 | Vissani MCWC50DST Wine Cooler
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
I have a Haier BC112G. It is not cooling at all. Temp panel works, so I can set the thermostat up or down, but nothing happens and it just goes back to room temp after that.
Our magic chef wine cooler (mcwc50dbt) when temp is set on digital panel at 45-50 it jumps immediately back to 70 degrees constantly
Sep 25, 2013 | Haier BC112G Wine Cooler
My wine cooler stopped cooling and running
What model # do you have? Is there anything working at all like lights, fans, or displays?
Sep 07, 2010 | Emerson (025806803716) Wine Cooler
THE UNIT DOES NOT COOL ANDY COLDER THAN ROOM TEMPERATURE.
does the compressor run ? if so you could have a low refrigerant charge, a sealed unit resrtiction, leak or defective compressor.
Apr 30, 2010 | Haier HVUE08A Wine Cooler
Vinotemp 2 zone wine cooler flashes "Lo" on numeric display for lower compartment - will not hold temperature requested. Temp in upper compartment will not go below 67 even though it is set for 51. Room...
Not sure, but did you clean the filter in the back? Ours has that, and the temp starts creeping up every few weeks until I clean it. But we've never been able to get it below 58 or so, and in the last year, not below 60. I think that's just the nature of this type of cooling. Our house is also at 80. But, can keep it at 60 with the above cleaning.
Jul 22, 2009 | VinoTemp (VT60GNV) Wine Cooler
Motor very hot; not cooling
If the compressor is hot it is possible that it is short cycling. Make sure the compressor is running and that the condenser fan motor is running if air cooled.
Mar 07, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
U-line 15" wine cooler not cooling, but light is on.
If the light is on and no fan or compressor is running then its your thermostat that is bad. Thats the only thing that turns on those parts.
Nov 25, 2008 | U-Line 15WC Wine Cooler
Wine cooler doesn't cool
you need to turn the temp. setting all the way up,use a rag to hold the fan,now see if the compressor. is running,let me know-mike
Jul 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
EdgeStar CWR530SZ - 53 Bottle Built-In Wine Cooler Logo
755 people viewed this question
Top EdgeStar Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you an EdgeStar Furniture Expert? Answer questions, earn points and help others
