Question about Frigidaire Affinity ATF7000E Front Load Washer
How to clean drain hose to frigidaire affinity front loader
Replace drain hose
Jeff Meyer
  • 423 Answers
One of the best ways to clean the drain hoze of a washing machine is to spool up the hose and place it into a bucket with at least 2 cups of vinegar (white or cider) and enough water to cover the disconnecfed hose. Soak overnight and rinse well before reinstalling.
Posted on Jul 18, 2014
5 Related Answers
Anonymous
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Posted on Jun 19, 2008
beltronic205
Gerry Harvey
  • 1481 Answers
SOURCE: fabric softener will not drain
Try cleaning out ..this should cure . the other thing that can cause this is a faulty solonoid valve as some machines have a seperate valve for this action....
Posted on Nov 25, 2009
Anonymous
  • 572 Answers
SOURCE: front loader frigidaire wont spin or drain final
in the bottom panel theres a coin trap
Posted on Feb 06, 2010
Jahn27
Jahn27
  • 1554 Answers
SOURCE: I have a frigidaire affinity front loader washer
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the electrical connections then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Posted on Jul 13, 2010
Michael Crozier
  • 196 Answers
SOURCE: How do I access the drain pump on a Frigidaire
If you cant access it from the front You will have to tilt the machine back as far as safely possible to access the bottom of the machine. Locate the drain pump which will be at the bottom font or back corner and remove the hose that connects the pump to the tub, you will need to have a basin ready to catch any water. You most likely have a sock or something stuck. Hope this helps
Posted on Mar 01, 2011
Frigidaire Affinity front loader washing machine
Try putting it on a stand, (most come with them) I think that the drain hose needs to be higher than the drain tube in your plumbing for it to fully drain.
Oct 24, 2012 | Washing Machines
My Frigidaire affinity washer front-end loader will not start. All hoses are fine, electrical is working fine, all doors are closed. I push start button and PAU flashes, That normal click or locking...
You may need to check the drain pump for anything that could obstruct the flow of water,or stop the impellar wheel from turning.if there is standing water in the unit you can use a wet dry shop vac to drain the water out by attatching it to the end of the drain hose.if you remove any of the hoses from the drain pump ther will still be some water that comes out.
Make sure to also check the boot that is coming from the bottom of the tub and make sure that the coin trap is not clogged.
The front panel has to be removed in order to get to the drain pump.I hope this helps good luck will be looking for any furher questions.
Oct 07, 2011 | Frigidaire Affinity ATF7000E Front Load...
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have a Frigidaire Front Loader Washer Model # ATFB6000FSO which at times does not drain or makes a loud noise during draining. I believe I have a clogged water pump or filter. What is the best way to...
You need to lean it back and remove the lower panel, you will have complete access to the water pump, disconnect hose clamps,remove and clean the rubber boot,disconnect electrical connector and 2 screws holding pump, Replace with new pump, before beginning take pictures to ensure proper installation
Nov 19, 2017 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire fron loader will not spin during wash cycle but will spin when placed on spin
If the drain pump is working correctly and you can get it to spin manually, then the board is faulty. Had the exact same problem with an Lg front loader 40 min. ago.(have to replace the board.)
Jun 14, 2010 | Frigidaire Affinity ATF7000E Front Load...
Front loader washer machine will not drain all water from rinse cycle
I would check the pump for objects, clean the filter, look into the hose adjacent to the pump for objects slowing the flow. I have a manual for you: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 24, 2010 | Frigidaire Affinity ATF7000E Front Load...
My washer is a whirlpool front loader. It keeps
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Jan 01, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire gallery front loader that is giving me an error code 20 what do i do
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Plug off the mains. You have to look for screws below the front kick-panel, you can raise the machine a bit to gain access to the screws, the panel comes down & out. You may find a drain hose here, on left, drain off the excess water. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. You can pass it into a large plastic bag. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Pl rate me nice for the free help!
Oct 11, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity washer
Suggestion:
Plug off the mains. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. There is a drain hose here, disconnect & drain out. There could be a lot of water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
For some front loader models after removing the panel, the filter is in the compartment having the white screw able lid. The big hose from the bottom of your tub leads to this compartment.
Mar 21, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
111 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
