RCA F25432 25" TV Logo
A
Anonymous Posted on Jul 17, 2014
Rca crt tv guide plus wont turn off for several minutes after turning on tv and dish. I have a satellite dish so removing the zip code causes picture to become snowy and whit horizontal and vertical s
Guide plus turns off after several minutes. I removed the zip code but than the dish picture is out of sync; both horizontal and vertical, snow and noise.
Level 3:
Top Expert:
  • RCA Master 76,851 Answers
  • Posted on Jul 18, 2014
RCA Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986646
Points
237762
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Nov 21, 2007
SOURCE: RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
A
Anonymous
  • Posted on Oct 05, 2007
SOURCE: Guide Plus
When the guide is on scroll to the right until you see setup then scroll down to review options. There you should be able to turn the guide off. Hope this helps.
Anonymous
  • 277 Answers
  • Posted on Apr 30, 2006
SOURCE: Guide Plus feature not working.
hi call your service provider and tell all this they will fix it or send you a man good luck
Anonymous
  • Posted on Feb 23, 2008
SOURCE: RCA TV f27422 TURN OFF THE GUIDE PLUS
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Bill
  • 245 Answers
  • Posted on Jun 24, 2009
Remove your zip code, I had the same problem, when I removed the zip code it went away.
I have a RCA guide plus gemstar t.v.I have lost the remote.to set up the guide plus in a new area I need to change the zip code.Its a 2003 model 36F53OT.where can I order one or an alternative solution.
you can access guide plus from front panel switches. press menu and select no. 7 or 8 guide plus setup. it asks for zip code type in using another remote using keypad.
My RCA has a black block come up in the bottom of the screen? We have Dish Network Satellite and have programed the remote from the remote code guide. TV volume and channel changer work, but picture is a...
This has hopefully been resolved for you, but if not, here are some steps to go through. The black box that comes on the screen is usually signaling that closed Captioning is activated on the tv. Closed captioning does not run through the DISH Network receivers, so you can turn that feature off in your tv settings. The fuzzy picture could be a few things. You will want to check that all of your cables on the back of the receiver box and tv are tight as possible, and also make sure that the tv is on the correct channel. If you are in the room with the receiver, the tv will need to be on channel 3 or 4, and sometimes an input; usually video 1 or 2. If you are in a number two room, where there is no receiver, than you want to make sure that the tv is on channel 60 or 73. I hope that this helps!!!!!
Becki Barned
DISH Network Customer Service
I can not get my tv to work with dish network
The RCA guide will not work with the dish remote. You can get the guide to close if you press the White TV button then press cancel. Remember to press the SAT button after you close the guide.
RCA tv with guide plus comes on and off randomly
these tv's are bad for caps in power supply, fluctuations freaking your micro.
2answers
Can anybody help me disable the Guide+ on my 52" RCA TV?
When you first turn your cable tv on go to the customer menu and turn off the G+, you should find it in your set-up section.
26helpful
5answers
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
11helpful
2answers
1helpful
2answers
36" RCA TV Wont power up
IP030 Regulator part number 263567/ Regulator overheating
1helpful
2answers
RCA F32450 TV
Question?
Answer:
Option A:
Select Setup.
Select Options.
Select Off.
Option B:
Select Off.
Option C:
Select Off.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
