Trueshopping NEW 2 STROKE OIL FUEL PETROL MIXING BOTTLE FOR STRIMMERS CHAINSAWS HEDGE TRIMMERS & MULTI TOOLS 25:1 50:1 Logo
A
Anonymous Posted on Jul 17, 2014
How do I mix two stroke engine fuel
None
Pat Smallwood
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Jul 25, 2014
Pat Smallwood
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
0
Helped
2498
Points
11
Put oil in your petrol can add the exact amount of petrol put the cap on shake well use and store out of sunlight
1helpful
JCB M25 strimmer, bought second hand does anyone know the fuel mix ratio please ?
TO MIX THE FUELSee Figure 3.? The product is powered by a 2-stroke engine and requires pre-mixing petrol with2-stroke oil. Pre-mix unleaded petrol and 2-stroke engine oil in a clean containerapproved for petrol.? The engine is certified to operate on unleaded petrol intended for automotive usewith an octane rating of 91 ([R+M]/2) or higher.? Do not use any type of pre-mixed petrol/oil from fuel service stations, such asthe pre-mixed petrol/oil intended for use in mopeds, motorcycles, etc. Do not useautomotive oil or 2-stroke outboard oil.? Use only synthetic 2-stroke oil.? Mix 2% of synthetic 2-stroke oil into the petrol. This is a 50:1 ratio
Feb 12, 2019 • Garden
I have a Ryobi RPT3000 trimmer. Firstly how do I top up engine oil? And then how do I restring it?
The engine on that trimmer will be a 2 stroke 30cc engine not a 4 stroke.
"Two Stroke Oil" is added to the fuel for a 2 stroke fuel mix in accordance with the proportions specified by Ryobi for that engine. The required petrol/oil mix may be printed on the top of the fuel cap. No other oil is used in a 2 stroke engine.
There are a number of videos on Youtube people have uploaded which will show you how to replace the pull cord on a trimmer.
I have a 1993 Honda 125cc was told to mix gas but these oil in crankcase do I need to mix?
You would never mix any fuel and oil for the crankcase. If it is a 2-stroke engine, the fuel and 2-stroke oil will need to be mixed before entering the cylinder. Some engines have an automatic mixing setup - those have a separate oil reservoir for 2-stroke oil, but it will usually be a plastic tank, located nowhere near the crankcase. On a "4matic" engine, it fires like a 4 stroke, but there is no crank case, and the fuel needs to be mixed like a 2 stroke. What is the vehicle you are referencing? A dirt bike or street bike? It seems the CR125 and NR125 are both 2 stroke engines, so somehow the fuel needs to be mixed with 2-stroke oil. Can you take a picture of the crankcase oil cap?
3helpful
What kind of oil do i use to mix with gas for my Poulan gas trimmer. Can i use WD30 motor oil or does it have to specifically say its for 2stroke engines? the ratio on the trimmer says 40:1 so i assume...
DO NOT USE MOTOR OIL!!!
There is a special 2-stroke engine oil mix that you can purchase at various stores that have outdoor equipment or you can also find mix at Walmart. There are instructions for proper mixing on the bottle.
Remember not to put 2-stroke mixed fuel in your lawn mower unless it is also 2-stroke (rare). And the converse is also true, do not put your 4-stroke lawn mower fuel in your 2-stroke weed eater.
If this is really helpful, please rate.
WHAT TYPE OF FUEL, STRAIGHT OR OIL/FUEL MIX & WHAT PROPORTIONS ?
Determine if your engine is a two-stroke or a four-stroke. Check the gas tank on your lawnmower or the owner's manual to determine what type of engine you have.
Read the label of your two-stroke oil. Follow the directions on the package to ensure the right mix.
Measure and pour the gasoline in to the empty gas can.
Add four ounces of two-stroke oil per each gallon of gas.
Replace the cap on the gas can and shake the oil and gas to mix. Add fuel to your engine.
Take care.
Jun 01, 2010 • Garden
What is the 2 stroke oil to fuel mix?
The fuel to oil ratio tells how much fuel and oil to mix for a given 2 stroke engine. It can be different depending on the recommedation from the manufacturer. NOT ALL 2 STROKE ENGINES USE THE SAME RATIO. You have to know the manufacturer recommendation for your engine.
Suzuki rm 250 2 stroke is leaking oil from the exhuast,is it a problem with the engine or am i mixing the fuel too rich
The standard mix is 4 ounces of two stroke engine oil to one gallon of gas. Do not use standard motor oil. Only use two stroke engine oil.
1helpful
Want to no if it takes petrol on its own when fueling or 2 stroke oil added to it aswell
i guess your asking if its a 2 stroke or a 4 stroke right ?
2 stroke engines dont have an oil filler cap , just a fuel filling point, the fuel used in a 2 stroke is just normal unleaded (aus) but you mix 2 stroke oil in the fuel before filling (about 50/1) or whatever it recomends.
4 stroke uses the same fuel but you dont mix the oil with the fuel , it has its own filler point for oil , however you must use a 4 stroke oil with these .
hope this is what you were after.
May 01, 2009 • Garden
1helpful
2answers
Do i have to mix 2 stroke oil on the gas for the 4 stroke bikes or just add regular gas on the tank? if is what is the scale for the mix?
DO NOT mix oil in the gas on your four stroke engine. You will foul the spark plug(s), build up deposits on the valves and head, and make a smokey, smelly mess. A two stroke engine uses the fuel/oil mix to lubricate the engine before being used as fuel. A four stroke engine has a separate lubrication system and does not normally burn any oil. As the name implies, a two stroke engine works in two strokes. The first stroke is downward, where the fuel/oil mix and air are drawn into the cylinder. The momentum from the crankshaft counterbalance or force from the other cylinder(s) drive the piston back up compressing the mix, and the spark plug sparks at or slightly before the top of the stroke. The rapid combustion of the fuel/oil/air mix drives the piston down, which is the power stroke, and then the cycle starts all over again. A four stroke engine has an intake stroke down taking in the fuel/air mix, a compression stroke up, a power stroke down as the fuel/air mix is ignited at or before the top of the stroke, and a exhaust stroke up before starting all over again. A four stroke is much cleaner and more reliable than a two stroke, but it is heavier and has less torque. A two stroke engine is much lighter and has more torque, but takes more maintenance.
Top Trueshopping Garden Experts
Jay Finke
Jay Finke
john h
Are you a Trueshopping Garden Expert? Answer questions, earn points and help others
