Question about OKI C6100n Laser Printer
Fatal error 231 error 3 - OKI C6100n Laser Printer
SiNnA
    Habit-Forming:
    New Friend:
  • 38 Answers
RFID Reader I/F Error An interface error was detected
with the RFID reader device.
01: communication error between
the RFID reader and the engine
PCB.
02: the transceiver circuit error of
the RFID reader.
03: communication error between
the RFID reader and the Tag
chip.
04: the RFID Tag detection error
Posted on Oct 27, 2015
4 Related Answers
Jeff Hughes
  • 97 Answers
SOURCE: fatal error 231 on oki c5800 after changing toner,
From the service manual, doesn't look good.
A technicain will have to look at the printer.
An interface error was detected with the RFID reader device.
01 : communication error between the RFID reader and the engine PCB.
02 : the transceiver circuit error of the RFID reader.
03 : communication error between the RFID reader and the Tag chip.
04 : the RFID Tag detection error (more than 4 chips).
If rebooting the machine does not improve the symptom, you need to
check the device.
Posted on Mar 29, 2010
ginko
Ginko
  • 19396 Answers
SOURCE: A message keeps flashing up
231 fatal error is telling you that the data from the chip on the toner cartridge is invalid or cannot be read.
This may happen for one of the following reasons:
1)The printer is unable to read the data on toner chip because of toner dust or dirt inside the printer.
Solution: Clean the printer inside, clean toner slot and drum.. See:Clean your laser printer.
2)Either the toner is not an original cartridge, it is refurbished or refilled, or the chip on the toner cartridge is defective.
Solution: replace the toner, or replace the Chip on toner cartridge.
3)The toner sensor in your OKI is defective.
Solution: Call the support number listed on the printer manual to arrange repair.
Posted on Jun 07, 2010
sinclair_cum
SiNnA
  • 38 Answers
SOURCE: SERVICE CALL 231: FATAL ERROR 03
THE RFID READER IS NOT CONNECTED CHECK CONNECTER TO THE LED'S AND TO THE BOARD AT THE BACK OF THE MACHINE
Posted on Dec 12, 2011
sinclair_cum
SiNnA
  • 38 Answers
SOURCE: 231 Fatal Error 03 means what
chip... THATS THE CHIP IN THE TONER CARTRIDGE
What does this message mean: 231 Fatal error 03
the RFID reader and the toner
cartridge.
02: Replace RFID R/W
board.
03: Check the antenna
cable connection
Feb 03, 2015 | Oki Electric Industry C8600n Led Printer
How can I fix oki c3530 231: fatal error 03?
PCB.
the RFID reader.
chip.
Jun 21, 2014 | OKI C5800Ldn Led Printer
Oki
231 means RFID reader I/F error. 03 means Communication error
between the RFID reader and the tag chip. The remedial measure is to check for normal connection of the antenna cable.
May 06, 2014 | Oki Electric Industry C830DTN Laser...
Printer stopped
Error 231 could be caused by multiple issues. The RFID R/W PCB, CU/PU PCB just to name a couple. This might be best left to an authorized service agent.
Nov 09, 2013 | Oki Electric Industry C610dtn Laser...
OKI C5650 231 FATAL ERROR 03
I tried putting 1.5mm of plastic foam under the RFID chip to raise it up in the toner cartridge. This seemed to work.
Jan 17, 2012 | Office Equipment & Supplies
Jan 10, 2011 | OKI C5500n Laser Printer
A message keeps flashing up 231 fatal error. Can you let me know what I need to do. 0116 240 3430 Dorothy
Jun 07, 2010 | OKI C5800Ldn Led Printer
Jan 10, 2010 | OKI C5500n Laser Printer
Fatal error message says ''231: fatal error 03''
It doesn't sound good, but a trick to try is to unplug the printer to see if that reset the board.
Nov 24, 2009 | OKI C5500n Printer
OKI C6100n Laser Printer Logo
779 people viewed this question
Top OKI Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
