Chances are that the water pump seal has deteriorated to the point where the water has leaked into the pump (and the floor) and caused problems with corrosion.
You might have had an E1 error code on the panel as well, if not, check out all the hoses for kinks etc then check the water pump condition for leakage. If it leaks, you will have to replace it as it is a sealed unit.
Dishwasher Problems - Water will not drain out
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
